Headlight Assembly, How to put together |
mmascari |
Jan 7 2017, 01:47 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
I am restoring my headlight assemblies so I took them apart and repainted them. Now I have to put them back together. I don't believe that my assemblies were together correctly to begin with.
My question revolves around the proper way to mount the round headlight mount to the main assembly. I did some research, looked at pictures, etc. I found some that had two springs while others had one. In addition some had one mounting screw and others had two. Looking at the two parts it looks like there should be two springs. Also, should the two assemblies be touching? Attached thumbnail(s) |
mmascari |
Jan 7 2017, 01:54 PM
I found this pic. This one has two bolts and one spring.
turnaround89 |
Jan 7 2017, 10:16 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
I just started restoring my headlight assemblies. I had two screws and one spring.
Now I Need to locate someone who has those screws because mine are rounded like no other. I thin the spring should be mounted on the inside holder closest to the hood. My thoughts, which could be totally wrong, are that the spring is used to pull the headlight towards the center line of the car to assist with proper alignment. Hope others chime in as well. Best of luck with your build! |
mmascari |
Jan 7 2017, 11:20 PM
I just started restoring my headlight assemblies. I had two screws and one spring. Now I Need to locate someone who has those screws because mine are rounded like no other. I thin the spring should be mounted on the inside holder closest to the hood. My thoughts, which could be totally wrong, are that the spring is used to pull the headlight towards the center line of the car to assist with proper alignment. Hope others chime in as well. Best of luck with your build! Thanks, that was how mine was put together as well....two screws and one spring. I also assume the two parts touch each other (at least where the spring holds the two together). |
Lo-Fi Version | Time is now: 9th May 2024 - 08:09 PM |
