Front Trunk Seal Glue |
mmascari |
Jan 7 2017, 06:35 PM
Member Group: Members Posts: 321 Joined: 1-September 14 From: Concord, CA Member No.: 17,850 Region Association: None |
I installed a new front trunk seal which fits great. Its from 914 Rubber. There are a couple corners, near the headlight bucket that wont seat. The seal lifts. I am thinking about putting a little glue in these spots to hold it down.
I know glue is not desired but I need the seal to stay put. What glue do you guys recommend? |
Mowog4 |
Jan 7 2017, 06:42 PM
Member Group: Members Posts: 288 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
I installed a new front trunk seal which fits great. Its from 914 Rubber. There are a couple corners, near the headlight bucket that wont seat. The seal lifts. I am thinking about putting a little glue in these spots to hold it down. I know glue is not desired but I need the seal to stay put. What glue do you guys recommend? My Choice would be 3M Weatherstrip Adhesive. |
Mikey914 |
Jan 7 2017, 06:59 PM
The rubber man Group: Members Posts: 12,660 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yep thats what I would use.
Mark |
mmascari |
Jan 7 2017, 09:30 PM
I installed a new front trunk seal which fits great. Its from 914 Rubber. There are a couple corners, near the headlight bucket that wont seat. The seal lifts. I am thinking about putting a little glue in these spots to hold it down. I know glue is not desired but I need the seal to stay put. What glue do you guys recommend? My Choice would be 3M Weatherstrip Adhesive. Thanks guys, I will pick some up. Mark |
shoguneagle |
Jan 8 2017, 01:21 AM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
YEP, THREE!!!
cary |
Jan 8 2017, 12:09 PM
When I installed the new seal in Mark's blue car I added a couple square pieces of cardboard over all the corners. It gave it just a little more down pressure on the black snot when the hood was closed.
second wind |
Jan 8 2017, 01:00 PM
Senior Member Group: Members Posts: 851 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
When I installed the new seal in Mark's blue car I added a couple square pieces of cardboard over all the corners. It gave it just a little more down pressure on the black snot when the hood was closed. I too have struggled to get rubber seal to stay put and have found that nothing sticks to the rubber. Will this 3M product do the trick? I have tried contact cement and epoxy and who knows what else? I am hoping new profile seal doesn't raise hood as much as well. Thank you! gg |
slotty008 |
Jan 8 2017, 01:10 PM
Member Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None |
The 3M 08008 adhesive is impossible to obtain in Belgium ( and Europe i suppose). Does anyone have an alternative?
mmascari |
Jan 8 2017, 01:14 PM
I just used the 3M adhesive as recommended and it worked fantastic. I had a couple corners that would lift and now they stay in place. I recommend it.
cary |
Jan 8 2017, 01:15 PM
Maybe Wurth W-8905401 ?
Mark Henry |
Jan 8 2017, 05:37 PM
Why glue it in? (IMG:style_emoticons/default/confused24.gif)
If it's not glued in you can take it out to keep the channel clean, dry and rust free. (IMG:style_emoticons/default/shades.gif) |
cary |
Jan 8 2017, 07:44 PM
The area protected with tape is the only area that I used adhesive on.
The rest was just fitted into the channel. It's really going to depend on the condition of your channel and or previous repairs on what will work. |
rgalla9146 |
Jan 9 2017, 06:01 AM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Read and follow the instructions on the 3M products.
It's also sold in rattle cans in a couple strengths....you'll have to mask.... but you'll get a uniform application. |
jkb944t |
Jan 9 2017, 06:45 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
I installed a new front trunk seal which fits great. Its from 914 Rubber. There are a couple corners, near the headlight bucket that wont seat. The seal lifts. I am thinking about putting a little glue in these spots to hold it down. I know glue is not desired but I need the seal to stay put. What glue do you guys recommend? My Choice would be 3M Weatherstrip Adhesive. I used the 3M just on the corners of my new seal and it worked great to hold it in place. I think I wiped the bottom of the seal with some prep-sol to make sure the 3M would adhere. The new seal from 914Rubber is a huge improvement over the older seal and I would highly recommend it! Jeff B |
lsintampa |
Jan 9 2017, 03:58 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
I did not and don't intend to glue mine. It sits in just fine and after a while, it relaxes a bit.
They don't seal well anyway, and water will ALWAYS collect in the corners... so after a bath (car never sees rain unless by mistake) I remove the gasket to clean out the channel it sits in. Rust is NOT are friend. That's my two cents! |
Mikey914 |
Jan 9 2017, 04:20 PM
The 3M product is not really a glue in the traditional sense.
It stays tacky so it grips but can easily be removed. |
Mark Henry |
Jan 9 2017, 04:59 PM
The 3M product is not really a glue in the traditional sense. It stays tacky so it grips but can easily be removed. Is it a different glue? (IMG:style_emoticons/default/confused24.gif) The 3M yellow super adhesive the sell at the FLAP's up here drys to a hard slightly rubber texture and it's a PITA to remove. To me I'd call it a water resistant contact bond cement and it smells exactly like it. I'd rather be able to remove it easy, to me the seal is a water trap. |
Mikey914 |
Jan 11 2017, 06:10 PM
The 3M product is not really a glue in the traditional sense. It stays tacky so it grips but can easily be removed. Is it a different glue? (IMG:style_emoticons/default/confused24.gif) The 3M yellow super adhesive the sell at the FLAP's up here drys to a hard slightly rubber texture and it's a PITA to remove. To me I'd call it a water resistant contact bond cement and it smells exactly like it. I'd rather be able to remove it easy, to me the seal is a water trap. 3M weatherstrip adhesive will not harden. It's like super sticky snott. Great visual, but the only way I can give you an of the texture. |
Lo-Fi Version | Time is now: 13th May 2024 - 06:05 AM |
