TYPE4PARTS PROGRAMABLE FUEL INJECTION |
Type 4 |
Apr 28 2005, 07:40 PM
Member Group: Members Posts: 412 Joined: 30-September 04 From: Costa Mesa Calif. Member No.: 2,866 |
Here is a preveiw of my fuel injection unit for the 914.
The Type4parts engine management system handles full 3D mapping of both ignition and injection. Its easy programmability and flexibility in adapting to existing engine installations and sensors make it a particularly good choice for people wishing to convert thier Bosch D Jet to mapped ignition and injection. The system will take inputs from the stock distributor including those converted to run with an optical trigger. The software provides 32 speed sites(up to 15,500RPM) and 16 load sites with tailored load site grouping, allowing super sensitive mapping around part throttle to improve drivability. The injection software provides the same number of load sites and speed sites, and also allows for cranking enrichment, acceleration fuelling adjustment, cold start correction, cylinder head and air temperature correction to both fuelling and ignition settings. Map trimming the timing and fuelling settings while the engine is running, or on a download basis. Type4parts EMS unit incorporates a shift light, user-tailorable soft and hard cut rev-limiters, tach drive and tach tell-tale. Not show in photo is modifided plemun for 65mm Throttle body. Attached image(s) |
