Celica racing radiator folks, bleeder valve? |
Chris914n6 |
Jan 13 2017, 02:52 PM
Jackstands are my life. Group: Members Posts: 3,321 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
What did you guys use for a radiator upper air bleeder valve?
Mine has a m10x1.0 hole that is pretty useless for this. Found this, but UK only Standard M10 Brass Bleed Valve |
76-914 |
Jan 13 2017, 06:26 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,503 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Shit, I don't remember seeing an opening to plug. Shoot a pic, will ya? (IMG:style_emoticons/default/beerchug.gif)
Andyrew |
Jan 13 2017, 08:30 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Threw some bolts in there that I sealed up after I used them for the initial bleed.
Mike Bellis |
Jan 13 2017, 11:28 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I have a 3' hose and a ball vale at the end. I can hang the ball valve up high to id in bleeding.
Krieger |
Jan 14 2017, 12:05 AM
Advanced Member Group: Members Posts: 4,713 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
What did you guys use for a radiator upper air bleeder valve? Mine has a m10x1.0 hole that is pretty useless for this. Found this, but UK only Standard M10 Brass Bleed Valve That looks like what is on the bottom of my Craftsman air compressor... |
Krieger |
Jan 14 2017, 12:25 AM
I bought a Uview Airlift tool on Amazon for my Boxster. You use this tool to create a vacuum in the cooling system when you refill it with coolant. Porsche repair shops use these.m It is really easy to use. I always wondered why you water cooled guys did not do use these.
Chris914n6 |
Jan 14 2017, 01:14 AM
Sorry it took so long Kent.... took the pic then decided to fit the factory fan shroud to the 'racing' radiator (IMG:style_emoticons/default/headbang.gif) Dremel with a sanding drum required.
Need to find bottom grommets that fit so I can start on the install. The old radiator used an inline bleeder on the top hose inlet. Both inlets are closer to the bottom on this one. |
76-914 |
Jan 14 2017, 09:17 PM
Sorry it took so long Kent.... took the pic then decided to fit the factory fan shroud to the 'racing' radiator (IMG:style_emoticons/default/headbang.gif) Dremel with a sanding drum required. Need to find bottom grommets that fit so I can start on the install. The old radiator used an inline bleeder on the top hose inlet. Both inlets are closer to the bottom on this one. Perfect timing Chris. Just got back to my computer, now. Thx. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 07:00 AM |
