Paint estimate |
Paint estimate |
socal1200r |
Jan 13 2017, 05:48 PM
Member Group: Members Posts: 73 Joined: 26-September 16 From: Virginia Member No.: 20,432 Region Association: MidAtlantic Region |
So I had a little free time this afternoon, and on a whim, took the car to three different paint shops to get an estimate on getting the exterior repainted. Man was I NOT prepared for the estimates! Can you believe between $5K to $6K for a fricking paint job?! WTF, over?! This isn't Gas Monkey Garage, Counting Cars, Unique Whips, or Bitchin' Rides for chrissakes! I'm thinking more like Wheeler Dealer! Maybe I should've told them this is not for a PCA Concourse event, or to take out the liquid gold in the paint mix. There's NO WAY I'm paying that much for a fricking paint job.
I was straddling the fence as to whether to keep this car or not, guess I know which way I'm going now... |
Randal |
Jan 15 2017, 12:07 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Painting is a ton of work to get right, but actually isn't all that hard, you just need to learn each step. It really helps to have someone to walk you through the basics, i.e., refurbishing, preparation and gun control/coating, then go for it.
The easiest way to learn is to practice all 3 or 4 steps with other metal material that you have. If you're using single stage paint you can always color sand out any runs, with two stage it actually easier as you put the first stage on, then correct any errors, then finish up with the top coat. I like two stage as you don't need much material for the color coat. If you screw something up, then just sand it out and recoat. Practice and your will find a way. I'm going to paint the DSR when it's ready. Going to follow the pattern in the second photo below, but use BRG as the base coat and silver for the front. Here's an example of final product that I didn't even need to color sand once I learned how to float final coats. |
Lo-Fi Version | Time is now: 14th May 2024 - 09:28 AM |
