Dropping Front Suspension and rack, help |
simonjb |
Jan 19 2017, 08:17 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Hi,
I need help ! I am trying to drop my entire front suspension including the steering rack. Everything is unbolted, and loose - except I can't seem to get the rack off the steering shaft. I have loosened the two bolts inside the drivers side of the car that seem to hold one part of the shaft to the shaft that goes through the front firewall. But the shaft is still in the U clamp. I can't seem to get the Bellow off under the gas tank - the PO burred the hex bolts. Any advice? |
simonjb |
Jan 19 2017, 08:24 PM
I can't get part number 27 off as the bolts (26) are burred. I have loosened bolts 35 but the shaft - part 33 - remains attached I can't get part number 27 off as the bolts (26) are burred. I have loosened bolts 35 but the shaft - part 33 - remains attached |
914forme |
Jan 19 2017, 08:27 PM
I can't get part number 27 off as the bolts (26) are burred. I have loosened bolts 35 but the shaft - part 33 - remains attached I can't get part number 27 off as the bolts (26) are burred. I have loosened bolts 35 but the shaft - part 33 - remains attached back out bolts #25, there are two of them. Deal with the rest latter. Bolts #35 have to be removed as the shaft is notched and the bolts pass through the notch locking the shaft to the U joint |
Jan 19 2017, 08:35 PM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Bolts #35 have to be removed as the shaft is notched and the bolts pass through the notch locking the shaft to the U joint (IMG:style_emoticons/default/agree.gif) |
simonjb |
Jan 19 2017, 08:43 PM
Thanks Guys!!
Any suggestions on the burred HEX bolts? |
bdstone914 |
Jan 19 2017, 08:51 PM
Thanks Guys!! Any suggestions on the burred HEX bolts? Get one of the sockets that have fingers inside that grab the hex unlike a standard hex shape. Is there any room to get in there with a 4" thin blad angle grinder and cut the bolts in two? Once you cut one the pressure is off the other. Or cut through the yoke. I will give you another ofr the shipping cost. Bruce |
turnaround89 |
Jan 19 2017, 10:12 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
QUOTE Thanks Guys!! Any suggestions on the burred HEX bolts? My hex bolts were completely rounded when I went to remove the steering rack. I went in with a dremel and cut a slot across the hex for a flat head screwdriver to fit into. Found the biggest flat head bit I had and placed that into a socket to attach to my impact wrench. One little burst from the impact wrench and the bolts came right out. |
falcor75 |
Jan 20 2017, 12:36 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Tapping a torx or xzn bit into the rounded hex holes also usually works.
914forme |
Jan 20 2017, 08:35 PM
Jan 20 2017, 09:06 PM
Cool! I did not know about these. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:46 AM |
