Sealing those big bores |
-JR- |
Apr 30 2005, 12:11 PM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
I've heard a lot of rumors that the over bore cylinders can not be made to seal. I'm refering to the larger bores like the 103 --> 105mm sizes. Does anyone have some feedback on their setup, how you are making out with them or how you got them to seal up?
Thanks! |
Bleyseng |
Apr 30 2005, 12:17 PM
One way is to use Nikkies........no problems then with head sealing
-JR- |
Apr 30 2005, 12:22 PM
What about the block sealing? |
Mark Henry |
Apr 30 2005, 12:26 PM
Cast iron cylinders warp causing head leaks.
If you had ever seen a case bored for 103's you'd know there's not a whole lot of material left over. Cheaping out at that size is just asking for trouble. Nickies or 96's are the only way to fly. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:38 PM |
