New Garage Lift |
New Garage Lift |
Unobtanium-inc |
Jan 22 2017, 06:21 PM
Advanced Member Group: Members Posts: 2,202 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
I was having the same problem that many of us have with the car addiction, no room to put them all. I was figuring out what to do and had a couple of options.
1. Buy a building to store them in. This wasn't ideal because it would be a lot of money and the cars would be away from me. 2. Build something else at my house. This wasn't ideal either because I live on a ridge, so my yard is a couple of acres but most of it is a sloping hill, so there wasn't anywhere really to build another garage. Then I had an idea. My two car garage had an attic above it. A friend was building a deck for me so I asked him if we could eliminate the attic and raise the ceiling in the garage. He said no if it was made with truss built, but if it was stick built, sure. Luckily it was stick built so all he had to do was raise the pitch, and he was able to re-use most of the existing lumber! Once the garage was where I wanted it, stage two came in, the lifts. The first lift went in today. My friend Greg helped me put it in, he also ordered it for me, he's the manager of the local NAPA. He had done one before but even with his experience it isn't a simple affair. There are lots of adjustments and a couple of times we had to take stuff apart and put it back together. It took 1.5 days, so it isn't as easy as the manufacturers make it out to be, but it is do-able if you're patient and know tools. I ordered the 2nd lift today and it should be here in a couple of weeks, which works out because the 3rd car, the 993, is coming Feb 4th and the 4th car the 65 Mustang fastback should be done around there too. So overall my review is you can put a lift in your garage yourself but it isn't super duper easy. Attached thumbnail(s) Attached image(s) |
green914 |
Jan 22 2017, 09:44 PM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
very nice remodel (IMG:style_emoticons/default/smile.gif)
bretth |
Jan 22 2017, 11:06 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
Cool. Just be aware of potential brake fluid leaks from the car in the top bunk so it does eat the lower cars paint.
Beett |
Unobtanium-inc |
Jan 22 2017, 11:16 PM
Cool. Just be aware of potential brake fluid leaks from the car in the top bunk so it does eat the lower cars paint. Beett Luckily it came with drip trays, and they are movable. Attached image(s) |
Krieger |
Jan 23 2017, 12:00 AM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
That looks really good! It looks like maybe two hours to snap those big Lego pieces in place. What took so long? (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif)
Unobtanium-inc |
Jan 23 2017, 06:41 AM
That looks really good! It looks like maybe two hours to snap those big Lego pieces in place. What took so long? (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif) If you watch the Youtube video it takes about an hour. There were a host of issues like my floor slopes for the main drain, so all four towers had to be syncronized with their locking ladder, one of which was put in backwards, so it had to be torn down and then re-built. I'm sure if I did 10 of them it wouldn't take long. But luckily you only have to build it once. |
Vysoc |
Jan 23 2017, 09:22 AM
Vysoc Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States |
Nice addition Adam, the 993 should be really fun to drive!
Enjoy, Vysoc (IMG:style_emoticons/default/flag.gif) |
Unobtanium-inc |
Jan 23 2017, 09:37 AM
Nice addition Adam, the 993 should be really fun to drive! Enjoy, Vysoc (IMG:style_emoticons/default/flag.gif) I'm hoping to make it my new autocross rat. It should be a lot of fun. |
Unobtanium-inc |
Feb 11 2017, 10:50 AM
A couple people have asked me what the difference between "stick built" and "truss built" is. My garage was stick built so we were able to loft the ceiling by moving the horizontal supports higher, we were even able to re-use much of the existing wood. If you garage has trusses you can't do this without making all new trusses, which is very costly.
Here is a pic of the garage mid-build. Attached thumbnail(s) |
Unobtanium-inc |
Dec 3 2017, 04:13 PM
Both lifts are in, winter is here, cars are up.
Hurry up Spring! Attached thumbnail(s) |
Dec 3 2017, 04:24 PM
Custom Member Group: Members Posts: 24,573 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Adam, keep an eye out for drips of the hydraulic fluid.
Many of these lifts use a cheap piston that has a split seal. |
Coondog |
Dec 3 2017, 04:29 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Looks great
Dec 3 2017, 04:33 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
A couple people have asked me what the difference between "stick built" and "truss built" is. My garage was stick built so we were able to loft the ceiling by moving the horizontal supports higher, we were even able to re-use much of the existing wood. If you garage has trusses you can't do this without making all new trusses, which is very costly. Here is a pic of the garage mid-build. I did the same with my house so I could have a 3rd floor office but instead of raising the floor, I raised the roof so I could have 8' ceiling. Also had to reinforce the floor. Won't do that project again. |
Unobtanium-inc |
Dec 3 2017, 04:47 PM
Kansas 914 |
Dec 3 2017, 05:41 PM
Cool. Just be aware of potential brake fluid leaks from the car in the top bunk so it does eat the lower cars paint. Beett (IMG:style_emoticons/default/agree.gif) It cost me a new paint job - well it cost the insurance company but it was a hassle beyond belief. |
pete000 |
Dec 3 2017, 07:05 PM
Does the 4 post lift require air compressor and 220 Volt?
sixnotfour |
Dec 3 2017, 07:15 PM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
the 3 ive had only require 110 volts
Unobtanium-inc |
Dec 3 2017, 07:22 PM
Unobtanium-inc |
Dec 3 2017, 07:23 PM
KELTY360 |
Dec 3 2017, 09:24 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
Is that 2+2 Mustang a Hertz?
Lo-Fi Version | Time is now: 4th May 2024 - 09:45 PM |
