Hydraulic lifters, Pros cons advice |
hseymore1 |
Jan 23 2017, 10:18 AM
Mid engine guy Group: Members Posts: 20 Joined: 14-November 10 From: washington state Member No.: 12,383 Region Association: Pacific Northwest |
I am considering building a second 1.7 engine as I have three good cases and lots of spare parts. I have a set of hydraulic lifters good crankshafts and cams. Can anyone give me so do's don't etc. that I should be aware of as I have only built stock engines?
Ferg |
Jan 23 2017, 11:10 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I'm sure I won't be the only one, but Don't use em. I really really dislike them.
ConeDodger |
Jan 23 2017, 11:14 AM
Apex killer! Group: Members Posts: 23,585 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Do: not use them...
Don't: use them... (IMG:style_emoticons/default/biggrin.gif) Loss of performance d/t loss of precision. Vs: no valve adjustments. |
Jan 23 2017, 11:23 AM
And you do still have to adjust the valves, particularly when the engine sits for an extended period of time.
--DD |
Mark Henry |
Jan 23 2017, 01:12 PM
Pro is they add weight to your scrap metal pile.
Con is they're junk. Personally I'd rather use dog doo for lifters. Learn how to adjust your valves, or pay a wrench to do it. Part of the package when you own a 914. |
rjames |
Jan 23 2017, 02:16 PM
I'm made of metal Group: Members Posts: 3,932 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I have them and I check that they are in adjustment once or twice a year, which they always are.
That said, I wish my engine didn't have them. If I don't drive the car for an extended period of time it can take a while for the lifters to fill with oil, and until they do it makes a horrible racket. Adjusting the valves isn't that difficult after you've done it a few times so don't let that be the deciding factor. |
hseymore1 |
Jan 23 2017, 02:48 PM
I am considering building a second 1.7 engine as I have three good cases and lots of spare parts. I have a set of hydraulic lifters good crankshafts and cams. Can anyone give me so do's don't etc. that I should be aware of as I have only built stock engines? Well it seems the verdict is no and I thank you all very much. |
JamesM |
Jan 23 2017, 04:51 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I am considering building a second 1.7 engine as I have three good cases and lots of spare parts. I have a set of hydraulic lifters good crankshafts and cams. Can anyone give me so do's don't etc. that I should be aware of as I have only built stock engines? I ran them for about 10 years on a 2.0 I had built back when I used my 914 for a daily driver. Never adjusted the valves once. They worked just fine but i wouldn't do it again. Adjusting the valves is not a big deal. quick edit: let me clarify "fine": On a daily driver below 4500 rpm they ran great as long as the car had not been sitting for a while and as long as the oil was clean. those are pretty much the operating parameters you need to say in to consider how they work "fine" |
larryM |
Jan 23 2017, 10:49 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
https://www.google.com/search?q=914+hydraul...-8&oe=utf-8 Dave Darling wrote w decent article about this many many yrs ago - it's on pelican i did it once - 20 yrs ago - it does not work with D-jet & oem cam - likely would work OK with a proper hydraulic cam - meaning a complete engine teardown & rebuild (35 hrs flat rate) - webcam has a couple performance Hydro cams to consider - mostly aimed at the VW market but good enuf |
cgnj |
Jan 24 2017, 03:58 AM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
If you use crmo pushrods with mechanical lifters, you can use zero lash braille method.
Beats feeler gauge, screwdriver and wrench, especially if the motor is stroked. |
Lo-Fi Version | Time is now: 14th May 2024 - 08:00 PM |
