Where Would I find an 'HA' gearset?, between stock ZD 5th and H gear |
Aaron Cox |
Apr 30 2005, 05:02 PM
for use with 205/50 15's (essentially 9.1% geared down)
just contemplating...., stock ZD is too short for socal freeway driving...., H is too tall working on my 'wonder box' 1- A 2- F 3- ZD flipped 4- V 5- HA flipped Attached image(s) |
rhodyguy |
Apr 30 2005, 05:16 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Aaron Cox |
Apr 30 2005, 05:18 PM
If I only could.....car gets crazy loud at 4k in a commute (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) need a slightly taller fifth BTW, speed limit down here is 70 in most places, traffic is 80-85 (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
ArtechnikA |
Apr 30 2005, 05:24 PM
PowerHaus-II shows a HB ( HB 19:31 1.63 ) gear. Charlie Davis' gear chart has an open spot where HA would be for a 901 box, so i donno if they "really" exist.
but try PowerHaus-II and see what they say. then report back... |
Joe Bob |
Apr 30 2005, 05:28 PM
POWERHAUS=$$$$
The H is only 4-5mph difference at 3500 rpms...that gonna kill ya? |
Aaron Cox |
Apr 30 2005, 05:36 PM
Flipped HB...
final speed output is 9.1% lower with 205/50 15's (essentially 9.1% geared down) Attached image(s) |
Aaron Cox |
Apr 30 2005, 05:39 PM
just thinkin aloud.....
BTW, what is an HB gear set out of? |
ArtechnikA |
Apr 30 2005, 05:44 PM
this one should be pretty easy :-) we know it's not a 914 ratio, therefore the answer is "some kinda 911 or 912 prior to 1972." you'll need to spend some time with ETKA, i think, to run it down - this is your project, not mine. just pray it's not a 911R ratio... |
Aaron Cox |
Apr 30 2005, 05:49 PM
thanks for the laugh (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) BTW- what is etka (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
ArtechnikA |
Apr 30 2005, 06:14 PM
Ersatz Teile Katalog, Electronische (Replacement Parts Catalog, Electronic) also called 'PET' here and there... |
propricer |
Apr 30 2005, 06:42 PM
Member Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
HB was the 2nd gear in the 901/06,10 and 12 as well as the 905/00,01 and 13.
HA was the 2nd gear in the 901/53,54,78,79,83 and 84 |
Aaron Cox |
Apr 30 2005, 06:44 PM
thanks mr ducey. BTW- second gears are fixed to the shafts i thought.... (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) |
bondo |
Apr 30 2005, 06:55 PM
Yup, that's bad news. Might not be available in a standard form. The H gear is easy, it's second in a 4 speed, and on the 4 speeds it's first that's fixed to the sahft. |
propricer |
Apr 30 2005, 07:17 PM
Just took an HB out of a 905/13 and it wasn't fixed to the shaft.
ArtechnikA |
Apr 30 2005, 07:20 PM
905 is a SportoMatic (and therefore 4-speed) - yes ? |
skline |
Apr 30 2005, 07:22 PM
I suggest you get the body work and paint done before you go changing any other mechanical stuff in your car. You are always complaing how it looks, stop worrying about the go faster parts and make it look good. Actually, it doesnt matter how it looks or runs, I am still going to spank you at the next AX. (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
propricer |
Apr 30 2005, 07:29 PM
Yes, 905 is a 4-speed sport-o-matic ... also has the VERY rare 7:27 R&P !!!
0396 |
Apr 30 2005, 08:05 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Aaron,
I have a slightly used HA. Bought it years and years ago for my 901 with a 904 mainshaft. I was going to give it to an old friend of mine- Topper C. for his collection.....but what's it worth? (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
Joe Bob |
Apr 30 2005, 08:25 PM
I paid 150 for my H gear while some freak on ebay got 500.... (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif)
redshift |
Apr 30 2005, 08:41 PM
You have 15 inch wheels? Why not go to 16s, and go up to stock rolling diameter?
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) See, I detest nerf tires, and you should too, although I know you like that frame rail on cement feel. M |
Lo-Fi Version | Time is now: 10th June 2024 - 09:32 PM |
