now where did I put those nuts?, or what size do I need |
theleschyouknow |
Jan 24 2017, 07:22 PM
Senior Member Group: Members Posts: 523 Joined: 4-June 13 From: Texas Member No.: 15,967 Region Association: None |
After a long time & little clean up & clutch cable work I'm starting to put stuff back together, anybody know where I put the two nuts that hold the cable pulley bracket to the trans?
I've got the pulley and washer and step nut & I remember cleaning those suckers but no idea where I put them, somewhere I wouldn't lose them I'm sure -but not bagged and tagged (big dumb dummy) If you don't know where they are can you at least help me out with the size/specs for some replacements? TIA (IMG:style_emoticons/default/beerchug.gif) cjl |
914Sixer |
Jan 24 2017, 08:36 PM
Should be the same nuts that hold the diff side cover on.
76-914 |
Jan 24 2017, 09:00 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
You put them someplace you wouldn't have to think about when needed later. (IMG:style_emoticons/default/lol-2.gif) I do that all the time and can't frigging remember where once needed. Looked all over Hell's Half Acre for a missing Hitch Pin. I had previously left it in the receiver so I would see next time I hooked up and wouldn't have to search for it. I looked everywhere but there. (IMG:style_emoticons/default/headbang.gif)
theleschyouknow |
Jan 25 2017, 10:22 AM
Should be the same nuts that hold the diff side cover on. yep i figured they were the same as the side cover, so... any idea what size the nuts are that hold the side diff cover on? I have looked in Haynes and Clymers and searched here but no luck (IMG:style_emoticons/default/beerchug.gif) cjl |
rudedude |
Jan 25 2017, 12:44 PM
Senior Member Group: Members Posts: 508 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest |
8x1.25 same as most other fasteners on the car
Olympic 914 |
Jan 25 2017, 12:52 PM
Group: Members Posts: 1,667 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
The PET shows that as being a Mid grip nut self-locking Part Number 999 090 101 02
Not much help there, But the studs are M8 So the answer would be ... M8 nuts |
theleschyouknow |
Jan 25 2017, 03:31 PM
thanks for the responses I'm going look for them a little bit more, then pick up some new ones, & then find the old ones
rgalla9146 |
Jan 25 2017, 05:01 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
thanks for the responses I'm going look for them a little bit more, then pick up some new ones, & then find the old ones (IMG:style_emoticons/default/beerchug.gif) cjl Have you looked on the trans ? |
mr914 |
Jan 25 2017, 05:13 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
Sounds like a good time to clean the garage.... (IMG:style_emoticons/default/sad.gif)
Went thru that in the quest for the lost keeper wedges between early struts and early ball joints. Someone, (IMG:style_emoticons/default/blink.gif) put them in the change tray on the dresser so he wouldn't forget them. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:52 AM |
