groot |
Dis member ![]() ![]() ![]() Group: Members Posts: 897 Joined: 17-December 03 From: Michigan Member No.: 1,444 ![]() |
Good job guys!
As Jake said, I will do what I can to make the Runoffs with my current engine and make the swap to RABY power later this season. I have enough races in the schedule, but CENDIV has a lot of production racers, and this year, everybody's out trying to make the last M-O Runoffs. With this engine, the strong GP guys motor by me no problem, so I'm left with the table scrapes for points.... if there aren't 10+ EP competitors (not uncommon in CENDIV). For example: GingerMan had 9 EP competitors and everyone knew the weather was going to be horrible. I have lots to learn about the car and myself, so bring it on. Next race: Grattan National, less than 2 weeks away.... 14-15 May |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,990 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
I went to Mylaps.com to look at the race results and the bargraph below is a sample of what they have.
I can directly compare my times with any competitor in the race. For instance, I looked at the times of the GTI and he did only 10 laps under 1:25, while I did 13 laps under 1:25. The gap between us grew to more than 6 seconds early in the race before I cut it back to about 2 seconds. I was working hard to catch up when I had my big off course, costing me 12 seconds. Then I continued to lay down some good times at the end. Attached image(s) ![]() |
ChrisFoley |
Here's a numeric listing of my times from Mylaps.
One thing I noticed after the race - I felt like I could continue racing a lot longer, as I wasn't tired. I attribute that to my morning workouts of running on a treadmill about 4 times a week while watching in-car videos. Attached image(s) ![]() |
ChrisFoley |
Mylaps.com uses data directly from the AMB transponders in all our cars.
It can even display live timing information. SCCA plans to have an in-car system available for displaying transponder data. No more need for a beacon at trackside with a sensor in the car. |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,859 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
Chris, you need to check out the new Hoosier R45A. Supposed to be really hot.
ChrisFoley |
I was using Hoosier Wets from 2003. I don't think they ever got hot. I plan on running Hoosier 35 compound slicks soon, and when I can afford it a new set of rains. |
Brett W |
I am not a Hoosier guy but one of the RX7s I work on runs them. The R45A is supposed to be softer than the R45 and last longer than the R35. Supposed to work out better than both. On your heavy car you could use something that last as well as sticks.
ChrisFoley |
I'll look into it Brett, thanks.
ChrisFoley |
After William Harris' camera died he borrowed mine and took a few more pics.
Starting with another one of Erik's car: Attached image(s) ![]() |
ChrisFoley |
Here are a couple of my crew (wife) working on the car:
ChrisFoley |
and
ChrisFoley |
Next, a couple of cockpit pictures:
ChrisFoley |
and
ChrisFoley |
Finally, a couple of suspension/brake duct shots:
ChrisFoley |
and:
(I'll be working on a video clip next.) Attached image(s) ![]() |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Sweet!
Just wait till we get the beast bolted back together and back in the car! Should not be long now, len is getting closer to being finished with the head repair! |
Lo-Fi Version | Time is now: 16th July 2025 - 09:06 PM |
