Slowly but surely, it's coming along.....pics |
J P Stein |
Apr 30 2005, 09:19 PM
Got the fuel system in today & the drivers door is back on.
Attached thumbnail(s) |
Aaron Cox |
Apr 30 2005, 09:21 PM
where does the oil cooler vent to? the hole in the bulkhead/floor?
J P Stein |
This looks like a gud place for this puppy. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
URY914 |
Apr 30 2005, 09:26 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,662 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I'm surprized to see you use that fuel pump.
How many gallons is your tank, less than 5 right? Paul |
J P Stein |
Apr 30 2005, 09:36 PM
Tomorrow, hood pins & black paint. My 2 new sticky buns should be in Tuesday.......hook up some wires & change springs ....it'll be ready for an alignment.
Note to self: Put some oil in the motor. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Aaron: Ayup, the 3 holes in the lower bulkhead. Paul: Ayup, 5 gallons...other than the noise, the Facet pump has done well for several years. It's kinda like my Pertronix, if the SOB would ever fail, I'll replace it with a gud one. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) To really shock you, I run it straight thru with no pressure regulator. |
URY914 |
Apr 30 2005, 09:37 PM
J P Stein |
Apr 30 2005, 09:51 PM
Ya'll gotta realize I report all my equiptment failures and my own fuck-ups here faithfully. Blown oil coolers (brain fade on my part......coil wire into the fan (likewise), plugged idle jets (Weber gods).....the fucker just don't break that often & I beat the livin' dog shit outta it....& my ex-co-driver did worser.
I didn't always use the "cats ass" parts except where I felt it was absolutely necessary.....Fluidyne cooler, Troutman Thermostat, new RS dizzy, the trans was done by the best guy in my area. I don't need thousand dollar headers....if they saved 50 pounds, I might consider them, tho. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Apr 30 2005, 10:06 PM
for some reason the direct hard connection between the pump and the tank makes me scared... I would think that a flexible line between those two, even if its really short, might be prudent.... My pump vibrates quite a bit, and its not the same as the tank vibration from the car/road/motor.. Rich |
J P Stein |
Apr 30 2005, 10:12 PM
SS braided hose from the tank to the carbs. You must be having an optional allusion. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) The fitting on the left of the pump passes behind the tank & 90s thru the bulkhead.
drgchapman |
Apr 30 2005, 10:23 PM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
hurry up Dude, We got shit to do..........Parade, WCC, keep'em em running.
Next A/X is next sunday. Need any help? Gary |
J P Stein |
Apr 30 2005, 10:43 PM
Well, yes. Come on over. Come early, I'm a day shift guy now. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:31 PM |
