Put deposit down on my new garage...., Change of plan..building two! |
billh1963 |
Jan 27 2017, 04:37 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Been thinking about my needs and realize that I not only need a conditioned work and storage place but I also need long term dry storage.
One big building would be nice. However, a large portion of it would be storage. That would be expensive to heat and cool. For the same money (actually a little less) I'm going with two 1200 sq. ft. garages linked by a 30' pad (the one in the drawing is 20' to save space on the drawing). This pad would give me a place to wash cars and work outside on nice days. The buildings will have 10' roll up doors on each end, one walk out door and two windows (around 6'-7' up for security) which are not shown in my rough drawing. The drawing is to scale with the cars being current 911 sized I put the deposit down today and have a few days to make any last minute adjustments. I had lots of good suggestions last time that I will be incorporating such as a loft (not shown on the drawings) . Based on previous feedback I need to spend more time thinking the layout of the bathroom (if I have one) and sink areas. The tool and storage rooms drawn are just for me to think about. Interior layout is something I will add later after the building are up. So, is there a fatal flaw or anything I am overlooking in this design? As I mentioned, I have a few days to make changes before the design/build process kicks off. Slab will be poured in around 4 weeks and building go up in 6 to 8 weeks. Garage_1_27_17_with_two___buildings.pdf ( 105.85k ) Number of downloads: 359 |
BK911 |
Jan 27 2017, 05:05 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
6 car garage with only one door?
Go with a single and double, or three singles. Personally I would go with one large building and put up a partition wall to separate conditioned vrs non cond space. And at least three doors on both ends!!! |
billh1963 |
Jan 27 2017, 05:32 PM
6 car garage with only one door? Go with a single and double, or three singles. Personally I would go with one large building and put up a partition wall to separate conditioned vrs non cond space. And at least three doors on both ends!!! Each building has two doors.... I might add an additional rollup door on the left building |
enf2232 |
Jan 27 2017, 05:39 PM
Member Group: Members Posts: 86 Joined: 13-July 14 From: Toledo, OH Member No.: 17,621 Region Association: None |
Check local zoning regulations. Two out buildings or accessory buildings may not be allowed without a variance.
Mark Henry |
Jan 27 2017, 06:04 PM
Personally I would do one building with an insulated wall with door and rollup down the center, heated one side unheated on the other. My buddy's shop is done this way.
Here I'd get taxed higher on two out buildings than a single bigger one. How tall? You need 12' for a two post lift. (IMG:style_emoticons/default/shades.gif) |
billh1963 |
Jan 27 2017, 06:24 PM
Zoning is not an issue. This is on my farm and no building permit is needed. I will need a permit for electrical work but not for building.
Both buildings are insulated.... roof and walls |
rhodyguy |
Jan 27 2017, 08:13 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,076 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Atleast do the plumbing rough in. Big concrete pours. Really cool plan.
db9146 |
Jan 27 2017, 08:26 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Maybe remove the single door on the west side of the left building and install two doors on the north wall of that building to ease moving cars in and out - I realize that might mean three rows of two instead of two rows of three. Less jockying around to get a car out potentially.
dakotaewing |
Jan 27 2017, 08:37 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
I know it would add to the cost, but I would consider putting a roof over the pad between the 2 buildings as a port'e cache (sp?), with the possibility of enclosing it in the future.
Jan 27 2017, 08:48 PM
914-6 GT in waiting Group: Members Posts: 19,260 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Terrific!
I agree with roughing in the plumbing. Cap it off and you can use the room for other things until your ready to do a bath. |
Jan 27 2017, 08:54 PM
I know it would add to the cost, but I would consider putting a roof over the pad between the 2 buildings as a port'e cache (sp?), with the possibility of enclosing it in the future. That's where you sit with your beer and bbq and relax looking at your cars. |
GaroldShaffer |
Jan 27 2017, 09:16 PM
The only problem I see is that we don't live closer and I am jealous that I don't have the space or $$ to do the same. Looks great! (IMG:style_emoticons/default/beerchug.gif)
rhodyguy |
Jan 27 2017, 09:27 PM
While you're pouring, concrete aprons sloped away at the outside end doors. Is this steel or pole construction?
rgalla9146 |
Jan 28 2017, 07:37 AM
Advanced Member Group: Members Posts: 4,551 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
"Zoning is not an issue"......... I want to move there !
All my stuff in one place. Studio for the wife. Warmer weather. 30' x 40' or 50' ....... |
JOEPROPER |
Jan 28 2017, 12:06 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Looks tight on the tool storage sides. Will need a few sets of "go jack" to move cars around. Other than that looks great.
KELTY360 |
Jan 28 2017, 12:45 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
First off, you can't have too many garage doors.
That said, in my opinion, the only way your design works is if you add enough width to the buildings so that you can park cars perpendicular to the side walls. That way, your central aisle becomes functional as a thru passage and individual cars can be moved at will instead of the jockeying now required. You could even install a four post lift(s) to increase storage capacity, depending on your roof height. BTW, where is your lift going to live? The arrangement I've described also makes it more convenient for displaying your cars as the storage area becomes a man cave. There are few things more fun than planning and executing a work and storage area for your cars. Good luck...enjoy! (IMG:style_emoticons/default/aktion035.gif) |
billh1963 |
Jan 28 2017, 12:46 PM
billh1963 |
Jan 28 2017, 12:57 PM
First off, you can't have too many garage doors. That said, in my opinion, the only way your design works is if you add enough width to the buildings so that you can park cars perpendicular to the side walls. That way, your central aisle becomes functional as a thru passage and individual cars can be moved at will instead of the jockeying now required. You could even install a four post lift(s) to increase storage capacity, depending on your roof height. BTW, where is your lift going to live? I've thought about two doors on the left building. That may allow better access. The cars are drawn about 20-25% bigger than they will be in real life to show a "worst case" scenario. The two post lift will be in the center aisle on the end towards the connecting concrete pad. 4 post lifts are in the future plans. It may also make sense to move the doors to the outer walls |
KELTY360 |
Jan 28 2017, 01:58 PM
First off, you can't have too many garage doors. That said, in my opinion, the only way your design works is if you add enough width to the buildings so that you can park cars perpendicular to the side walls. That way, your central aisle becomes functional as a thru passage and individual cars can be moved at will instead of the jockeying now required. You could even install a four post lift(s) to increase storage capacity, depending on your roof height. BTW, where is your lift going to live? I've thought about two doors on the left building. That may allow better access. The cars are drawn about 20-25% bigger than they will be in real life to show a "worst case" scenario. The two post lift will be in the center aisle on the end towards the connecting concrete pad. 4 post lifts are in the future plans. It may also make sense to move the doors to the outer walls I'm going to be a 'buttinski' here so I won't be offended if you tell me to butt out. How many cars do you expect to be working on at any given time? Work-around space in the shop area is very important and you don't want to squeeze yourself as you move around the area. Floor space for things like engine, trannies, sheet metal must also be allowed for. Your current design makes moving things around like one of those slide puzzles where you have to shift tiles in order to get a certain tile from one side of the puzzle to the other. Open space is your friend. If the two post lift is in the middle of the aisle near the door you'll create a logjam if there's a project on the lift and you want to move something else around to the other building. Trust me, it happens. I've done a quick example showing a 35x40 (1400 sq ft) that could hold 6 cars with 10' rollups at both ends and easier circulation. I'm sure you can find space for benches and storage in this configuration. Note that the aisle is not straight-thru, but it's still wide enough to navigate safely with sufficient space allowed at the entrance and exit. Obviously, roof height and configuration are affected with the offset aisle, but those details can be worked out under the 'buttinski license". Good luck. 35x40_shop.pdf ( 215.02k ) Number of downloads: 136 |
billh1963 |
Jan 28 2017, 02:43 PM
Not a bad idea. Shift the doors to the side allows "turn in" space. Two 4-post lifts would really change storage capacity (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 12th May 2024 - 12:55 AM |
