Back to the grind, Turbo Valve cover milling question |
forrestkhaag |
Jan 27 2017, 08:04 PM
Can someone with experience describe the milling tolerances needed to gain clearance on a 914-6 (3.0) with Turbo Valve covers. My jangled understanding is that in order to be able to do a valve tune, one must remove material from the raised fins on the Turbo covers / lower obviously?..
Also, can valve covers withstand the heat involved in powdercoating? |
Jan 27 2017, 08:09 PM
Yes, powdercoating is fine. I believe I had 5/8 milled off the fins
db9146 |
Jan 27 2017, 08:19 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Did you see the recommendation earlier this week on another post regarding this topic that suggested replacing the offending locking nuts with cap head allen screws and spring & flat washer combinations since the torque values are so low?
I thought it was a really good suggestion to keep from having to mill the web on the covers and plan on ordering the needed hardware as soon as I pull a stud and get a measurement on the proper length.....unless someone reads this who already knows and is willing to enlighten us. |
forrestkhaag |
Jan 27 2017, 08:34 PM
I like the new bolt verses nut-n-stud (cap screw) idea / if one doesn't need to mill. Ethan?
(IMG:style_emoticons/default/beerchug.gif) |
Jan 27 2017, 08:57 PM
No, you don't use bolts for that application. Porsche used studs for a reason.
raynekat |
Jan 27 2017, 09:30 PM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
brant |
Jan 27 2017, 10:01 PM
Also the correct milling procedure is to not install them until the motor is in the car
Then you mill them to install. If you mill them enough to go on then you know they will come off Every chassis is a little different tolerance. And motors can vary minutely also |
shoguneagle |
Jan 28 2017, 12:54 AM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
I really like Brant's suggested method and the reasoning. Valve adjustments are done every 15000 miles on my 3.2 and I have not milled the turbo covers yet. Had the engine out several times to re-seal and transmission repair; gave it a general look see and adjusted valves then. What a pain just to adjust the valves.
Making my next project the valve cover milling. |
Jan 28 2017, 06:08 AM
The naro motorsports pivoting engine mount makes dropping the engine so much easier. It's more like opening a door vs taking it off its hinges.
Mark Henry |
Jan 28 2017, 08:52 AM
I just milled all the fins off leaving about an 1/8".
Looks clean and doesn't hurt the strength of the turbo cover. BTW if you already have SC covers the turbo covers are a waste of money, only the earlier mag covers were leakers. |
sixnotfour |
Jan 28 2017, 11:26 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/agree.gif) I collected every discarded pair of SC lowers I could...
no turbo covers for me |
IronHillRestorations |
Jan 28 2017, 11:50 AM
I've taken 5/16" off the entire top of the ribs, and that's worked.
Larmo63 |
Jan 28 2017, 12:03 PM
I will get the Turbo covers and use Brant's method. Thanks for the idea.
Damn you guys are good. (IMG:style_emoticons/default/beerchug.gif) |
forrestkhaag |
Jan 31 2017, 05:27 PM
I will go the Perry Kiehl route once the engine is in and I can remill if needed.
Thanks guys. (IMG:style_emoticons/default/first.gif) |
fixer34 |
Jan 31 2017, 07:43 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Larmo63 |
Jan 31 2017, 08:39 PM
The naro motorsports pivoting engine mount makes dropping the engine so much easier. It's more like opening a door vs taking it off its hinges. Does the PMS mount qualify here, too? (IMG:style_emoticons/default/smile.gif) |
porschetub |
Jan 31 2017, 08:47 PM
No, you don't use bolts for that application. Porsche used studs for a reason. (IMG:style_emoticons/default/agree.gif) don't go there,the threads on the cam box will eventually strip out ,personally I would stick with the stock covers and forget the milling job,as mentioned before the alloy covers don't stay flat ,mill off the ribs and that will happen faster (warpage) and that's according to the clever engine builders on Pelican who say they do warp in stock form. Get your old ones and resurface them with a sheet of sandpaper glued to a piece of glass ,buy the correct exhaust cover lower gaskets and all will be golden,sell your turbo covers to a 911 guy. Did my magnesium ones and bone dry now....they were really bent (IMG:style_emoticons/default/sad.gif) |
Mark Henry |
Feb 1 2017, 06:12 PM
...personally I would stick with the stock covers and forget the milling job,as mentioned before the alloy covers don't stay flat ,mill off the ribs and that will happen faster (warpage) and that's according to the clever engine builders on Pelican who say they do warp in stock form. Get your old ones and resurface them with a sheet of sandpaper glued to a piece of glass ,buy the correct exhaust cover lower gaskets and all will be golden,sell your turbo covers to a 911 guy. Did my magnesium ones and bone dry now....they were really bent (IMG:style_emoticons/default/sad.gif) That's a load of poop on the milling and about the mag covers. The studs and squaring up info is good. Turbo covers are over-kill it won't hurt them one bit by milling off the ribs. SC don't have much in the way of ribs and they work fine. It's the magnesium covers that have the issues, they can warp just bolting them up. If you already have turbo covers keep them and mill or clearance them. If you have SC covers keep them. if you have mag covers, unless you have a concours car get the SC or turbo covers. My covers, I looked and they're milled to just under 1/4". Same height as the stud/nut boss. Attached image(s) |
Lo-Fi Version | Time is now: 15th May 2024 - 11:26 PM |
