Question #2: How much shine can you put into fuch's alloys? |
McLovin |
Jan 30 2017, 04:09 PM
Member Group: Members Posts: 102 Joined: 31-August 16 From: Tallahassee, FL Member No.: 20,360 Region Association: South East States |
How shiny can you make Fuch's alloys? Any tips or tricks you care to share? How often do they need to be polished?
Cairo94507 |
Jan 30 2017, 04:14 PM
Michael Group: Members Posts: 9,750 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
They were never polished or chromed from the factory. Personally, I like the stock look or on flared cars I like the RSR finish. Other than that, buff away. (IMG:style_emoticons/default/unsure.gif)
Jan 30 2017, 04:23 PM
How shiny can you make Fuch's alloys? Fuchs is a name and not plural, there is no such thing as a single "Fuch" wheel. Fuchs is the name of the company, meaning there will always be a "s" at the end, even if it is just a single wheel. (IMG:style_emoticons/default/shades.gif) |
McLovin |
Jan 30 2017, 05:15 PM
How shiny can you make Fuch's alloys? Fuchs is a name and not plural, there is no such thing as a single "Fuch" wheel. Fuchs is the name of the company, meaning there will always be a "s" at the end, even if it is just a single wheel. (IMG:style_emoticons/default/shades.gif) Thanks. I knew that. Put the apostrophe in there out of habit. I do the same with "it's", even though I know the proper usage. |
rgalla9146 |
Jan 30 2017, 06:00 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
To polish them you have to remove the original protective surface finish.
After you've accomplished that you're in for a life o'polishin. |
Mueller |
Jan 30 2017, 06:22 PM
Same as anything bare aluminum. Mothers works well. Any decent youtube tutorial on the subject will show you, nothing special about the rim if you want it polished.
If real and unpolished you might have to remove the clear anodizing, Easy Off oven cleaner works or sanding. |
Mark Henry |
Jan 30 2017, 06:35 PM
Easy Off oven cleaner works or sanding. Please don't sand without taking off the anodizing first (IMG:style_emoticons/default/sad.gif) Use a weak solution of lye (sodium hydroxide, caustic soda...all the same thing) to strip the anodizing, then you can sand progressing to finer grits and polish. Many, but not all, toilet bowl cleaners and I suspect easy-off use sodium hydroxide as the active ingredient. |
jsaum |
Jan 30 2017, 07:11 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
You can get a nice finish I went down to 2000 grit sandpaper and close to 20 hours on one rim. Then I used the red and white clay and a buffing wheel for the final finish. So far it's holding up pretty good with the Mothers cleaner and polish.
Attached thumbnail(s) |
McLovin |
Jan 30 2017, 08:52 PM
You can get a nice finish I went down to 2000 grit sandpaper and close to 20 hours on one rim. Then I used the red and white clay and a buffing wheel for the final finish. So far it's holding up pretty good with the Mothers cleaner and polish. That looks amazing! Please show your whole car. How long has it been since you completed the buffing? How much effort is it to maintain it? (like how often do you put on the Mothers cleaner and how long does that process take?) In your opinion, was it worth it to remove the protective coating? Since I'm kind of a lazy guy, I can't help but wonder if you could have gotten comparable results in a shorter time by using different products/sanding grits? How many grits did you use on your way down? Did you do it by hand, or with a power tool? Anyone else get similar results in a shorter time? |
Krieger |
Jan 30 2017, 09:04 PM
Advanced Member Group: Members Posts: 4,707 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
From my experience, it seems like the forged wheels are harder to polish than a cast alloy. They also hold the polish a lot longer.
Jan 30 2017, 09:15 PM
RichPugh |
Jan 30 2017, 09:27 PM
Member Group: Members Posts: 124 Joined: 28-October 14 From: Baltimore, MD Member No.: 18,068 Region Association: MidAtlantic Region |
QUOTE There are no shortcuts. Be prepared once you commit. Well... you could just send them to Frank... haha. https://m.facebook.com/shorepolish/ |
rgalla9146 |
Jan 30 2017, 09:46 PM
....or you could buy a Corvette |
TJB/914 |
Jan 30 2017, 10:00 PM
Mid-Engn. Group: Members Posts: 4,327 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
polished and lots of dirty work (IMG:style_emoticons/default/happy11.gif)
Pay someone else to do the job. T Attached thumbnail(s) |
Larmo63 |
Jan 30 2017, 10:13 PM
McLovin |
Feb 2 2017, 09:03 AM
So how shiny can you get them if you don't burn through the anodized coating? What's a good polish for that?
KELTY360 |
Feb 2 2017, 10:34 AM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
So how shiny can you get them if you don't burn through the anodized coating? What's a good polish for that? Describe the color red. (IMG:style_emoticons/default/dry.gif) |
arne |
Feb 2 2017, 11:02 AM
Serial Rescuer of old vehicles... Group: Members Posts: 737 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
So how shiny can you get them if you don't burn through the anodized coating? What's a good polish for that? |
McLovin |
Feb 2 2017, 12:29 PM
So how shiny can you get them if you don't burn through the anodized coating? What's a good polish for that? Thanks, Arne. Kelty: I'll get back to you on that one. Ok, trying to crack the nut another way, has anyone tried this? http://www.fastlinecoatings.co.uk/pics/x5wheels.html more info: http://jalopyjournal.com/forum/threads/chr...n.554420/page-2 |
Mark Henry |
Feb 2 2017, 12:33 PM
Fastest way is to DIY is strip them with the weak lye solution I discribed, then bead bast them and start sanding and polishing.
I had about 6 hours total into each rim this way. Pro shops do the same lye solution, then they use an expensive tumbler filled with ceramic beads. The powdercoat chrome called Ceramichrome (IIRC) isn't cheap last time I checked. |
Lo-Fi Version | Time is now: 14th May 2024 - 06:07 PM |
