QUOTE(jsaum @ Jan 30 2017, 08:11 PM)
You can get a nice finish I went down to 2000 grit sandpaper and close to 20 hours on one rim. Then I used the red and white clay and a buffing wheel for the final finish. So far it's holding up pretty good with the Mothers cleaner and polish.
That looks amazing! Please show your whole car. How long has it been since you completed the buffing? How much effort is it to maintain it? (like how often do you put on the Mothers cleaner and how long does that process take?) In your opinion, was it worth it to remove the protective coating?
Since I'm kind of a lazy guy, I can't help but wonder if you could have gotten comparable results in a shorter time by using different products/sanding grits? How many grits did you use on your way down? Did you do it by hand, or with a power tool? Anyone else get similar results in a shorter time?
