911 rear handbrake repair, stub axle won't go back in ? |
porschetub |
Jan 31 2017, 06:31 PM
As per title removed my wheel hub to repair 911 handbrake setup,completed repair and now I can't get the stub axle to pull back into the hub,any ideas gents? TIA
rgalla9146 |
Feb 1 2017, 01:52 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The hub into the bearing is a press fit.... It's important to start it straight..... if not things get bad. Stub axle into hub ? it should feed in easy if the splines are clean. If they're grubby or rusty it can be tough. Remove crud with wire wheel and a pick. |
porschetub |
Feb 2 2017, 12:24 PM
Thanks for the info,you say the hub is pressed into the bearing,mine after being undone tapped out with a soft hammer,I haven't disconnected the CV shaft so I think that's the reason for my grief......
Lo-Fi Version | Time is now: 16th May 2024 - 12:02 AM |
