porschetub
Jan 31 2017, 06:31 PM
As per title removed my wheel hub to repair 911 handbrake setup,completed repair and now I can't get the stub axle to pull back into the hub,any ideas gents? TIA
rgalla9146
Feb 1 2017, 01:52 PM
The hub into the bearing is a press fit....
It's important to start it straight..... if not things get bad.
Stub axle into hub ? it should feed in easy if the splines are clean.
If they're grubby or rusty it can be tough.
Remove crud with wire wheel and a pick.
porschetub
Feb 2 2017, 12:24 PM
Thanks for the info,you say the hub is pressed into the bearing,mine after being undone tapped out with a soft hammer,I haven't disconnected the CV shaft so I think that's the reason for my grief......
