Fuel sender ohm range |
vin man |
Feb 3 2017, 11:50 AM
Member Group: Members Posts: 178 Joined: 19-February 10 From: Gilbert, Arizona USA Member No.: 11,380 Region Association: Southwest Region |
Can someone tell me the ohm range for the original fuel sending unit in my 72 914? I'm ordering new, aftermarket gauges and want to use my original sender.
Thanks. |
914Sixer |
Feb 3 2017, 01:29 PM
90 ohms
vin man |
Feb 3 2017, 02:55 PM
90 ohms Thanks for answering my question. That is a range. (IMG:style_emoticons/default/smile.gif) I should have asked, "What is the ohm reading on Empty and the ohm reading on Full?" The gauges are usually set up for a big to small reading or small to big reading. (empty to full) |
Feb 3 2017, 04:50 PM
The 914 sender is backwards. It's 90 ohms empty, and something like 10 full.
--DD |
vin man |
Feb 3 2017, 05:18 PM
The 914 sender is backwards. It's 90 ohms empty, and something like 10 full. --DD Thanks Dave. I ordered the wrong gauge. I ordered zero empty and 90 full. Will try and change it. I ordered the Auto Meter 3314 ATM 3314 The only thing close to what Dave is stating is the one that goes from 73 ohms empty to 10 ohms full. Is that the one I need? ATM 3315 |
turnaround89 |
Feb 3 2017, 05:46 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
It's more expensive but you could buy the atm 3310.
atm 3310 The gauge is programmable to any ohm range. I used one of these on my first car and now am using a speedhut adjustable fuel gauge. They are easy to program. |
vin man |
Feb 3 2017, 07:02 PM
It's more expensive but you could buy the atm 3310. atm 3310 The gauge is programmable to any ohm range. I used one of these on my first car and now am using a speedhut adjustable fuel gauge. They are easy to program. That would have been a good option too. I called Summit and switched it to the 3315. Thanks. |
Lo-Fi Version | Time is now: 14th May 2024 - 09:04 PM |
