FS: Boxster Hubs, One 944 Turbo Stub Axle $89 shipped, Cheap Toys for someone that wants to Play |
914Sixer |
Feb 4 2017, 03:27 PM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
These Boxster hubs will fit in 914 rear arms. You must use a flat plate bearing holder. Grind the ears off of the stock ones or get some all ready done from Tangerine Racing. 944 turbo stub axle is a drop in fit HOWEVER you will need a ring spacer made up for it to make if flush with the bearing. You then can use the 944 CV joint described in the Classic section. On the transmission side you will need 915 coarse spline 100 mm flanges.
I never did get around to fitting a Boxster rotor and caliper for find out how that would work out. $89 shipped Paypal: a914nut@email.com Attached image(s) |
Chris914n6 |
Feb 4 2017, 03:30 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Do 914 rotors work with these?
914Sixer |
Feb 4 2017, 04:40 PM
Yes they will but there is no way to secure them to the hub. Screw holes do not line up. Did not see any way to redrill them either.
914Sixer |
Feb 8 2017, 06:17 AM
914Sixer |
Feb 18 2017, 05:19 PM
Lo-Fi Version | Time is now: 28th May 2024 - 11:56 PM |
