| Mueller |
May 4 2005, 09:08 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
putting the camera on a tri-pod helps...too much coffee normally (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) glad the laptop(s) are working, hate to see them go to waste.... |
| Mueller |
May 4 2005, 04:56 PM
James or anyone else:
any real difference between the ceramic resistors and the aluminum bodied resistors other than heat dissipation being better with the aluminum bodied units??? |
| lapuwali |
May 4 2005, 05:32 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Not that I know of, no. Resistors are basically just resistors. Ohms, tolerance, and power rating are all that matter. I suppose the Al units might be smaller for a given power rating, which would be useful in some cases.
| Mueller |
May 4 2005, 05:39 PM
thanks...I picked up the ceramic style at Frys for .99 cents instead of the aluminum ones at $5 each @ R and D Electronics..........I'll mount them on a heatsink I pulled out of an old Pentium workstation |
| Mueller |
May 4 2005, 06:10 PM
now I know why I don't throw too many things away....for the resistors, I need heatsinks.....threw away a few Pentium II systems but took a few items out of the case before being tossed:
The blue one houses the 2 resistors I need for my fuel injection......... Attached image(s)
| Mueller |
May 4 2005, 06:11 PM
bottom view, I still need to figure out how I will mount this in the car...no heatsink grease on the parts yet....
| Aaron Cox |
May 4 2005, 06:15 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
thats a lot of heatsync....
where are you going to put it all? (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
| Britain Smith |
May 4 2005, 07:11 PM
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
On the topic of heat sinks, where can I get some nice panel mount type connectors? I want to use them on the firewall of my car so that I can put all the electronics inside the car and be able to just plug it in. I would like to be able to remove the ECU from the inside of the car and plug it into the engine directly when the engine is on a dyno. I would probably need to connectors, each with about 20 pins.
-Britain |
| Mueller |
May 4 2005, 07:13 PM
Mouser, Digikey....Jasons storage shed (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| TimT |
May 4 2005, 07:18 PM
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
Britain look on page one of this thread, there is a pic of a 26 pin weatherpac connector Im using on my 911. Just one plug pulled, a few hoses and the engine is out.
| Mueller |
May 4 2005, 07:27 PM
| Britain Smith |
Where did you get it?
I really want a panel mount connector that can mount to the firewall. Kinda like the ones on the bottom of this picture. (IMG:http://www.v8914.com/Images/Big/Wiring3.jpg) -Britain |
| TimT |
May 4 2005, 07:33 PM
Oh duh, brainfart, Clewett sells that 26 pin connector.
Britain, the connectors in your pic can be sourced from MoTec or EFI Technology. I haven forgotten the trade name for those connectors, but they are Mil-spec aircraft connectors.. |
| Mueller |
May 4 2005, 07:46 PM
Think those might be Deutsch brand connectors??? Deutsch Connectors |
| Mueller |
May 26 2005, 03:23 PM
ditched the stock relay board....had to come up with a "cheap" solution for the 14 pin and 12 pin connector (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
I ended up drilling the pins out of the relay board... Attached image(s)
| Mueller |
May 26 2005, 03:25 PM
i then soldered them to female sockets from the 12pin connector and placed them in the correct socket of the 14pin connector...
Lo-Fi Version | Time is now: 2nd April 2026 - 07:39 AM |
