Questions on exhaust for newb, was curious |
DrifterJay |
Jun 28 2003, 11:32 PM
I break stuff... Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None |
ok, I am a total newb when it comes to Porsches... I have been converting from Hondas and other japanese crap to something better. Explain how the exhaust system works. Like the heat exchangers and other bs. Also when someone gets a header system, does that remove the heat exchangers? Also, what compromises the 914 exhaust? Is there an 02 sensor, cat converter and such? Or is it a straight pipe. Keep in mind I will be getting a 72 1.7...Basically..from motor to tailpipe what is there. lol. Also, I have examined the car I am to be purchasing soon and rust is minimal..very little battery tray corrosion. Well the car has a old aftermarket exhaust system with dual outlets. In fact..its something like this 00 00. If that makes sense. I think the heat exchangers are there on it..I see all this tin around the exhaust. Are those the exhangers? Could someone post a pic of the exhaust with exchangers so I know what to look for? Also, should I change that exhaust to a single outlet, for reasons of too much backpressure loss? Ok thats a ton to digest..sorry for the long post. Oh yes, one more, what kind of exhaust is this?
THANX Jared (IMG:style_emoticons/default/wink.gif) Attached image(s) |
Andyrew |
Jun 29 2003, 12:20 AM
My best guess would be a really loud header system with glasspacks for a 6 cylindar..
the tin moves the hot air from the hot heat exchangers to the heating system. There is a cat on the later cars. From motor to tail pipes, uhh heat exchangers and a muffler. Thats all I know! The rest are my same questions (IMG:style_emoticons/default/tongue.gif) Andrew |
DrifterJay |
Jun 29 2003, 12:55 AM
Why am I listening to someone a year younger than me??? just playing..lol.
Jared (IMG:style_emoticons/default/wink.gif) |
Jun 29 2003, 01:04 AM
Resident German Group: Admin Posts: 41,632 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
if your exhaust looks like the one in the pic below, it's a MANTA (aftermarket).
they are not too bad, according to brad a bit weaker than a bursch, but i guess only a dyno-session could really tell ... (IMG:http://www.sirandy.com/pix/914/back1.jpg) |
DrifterJay |
Jun 29 2003, 01:06 AM
thanx...I finally know what it is, it is identical to the one there...but thats a six right? I have it on a little 1.7...
Jun 29 2003, 01:15 AM
heat-exchanger:
basically, you blow cold (well whatever air you have that day) air over your HOT exhaust pipe to heat it up and then push it inside the car. see pic below. a "header" system is simply just the exhaust pipe with no heat exchanger ... Andy Attached image(s) |
QUOTE(DrifterJay @ Jun 29 2003, 12:06 AM) thanx...I finally know what it is, it is identical to the one there...but thats a six right? I have it on a little 1.7... Jared (IMG:style_emoticons/default/wink.gif) nope, mine is a /4 1.8 (IMG:style_emoticons/default/wub.gif) |
DrifterJay |
Jun 29 2003, 01:27 AM
Thank you professor Andy for today's lesson! (IMG:style_emoticons/default/beer.gif)
Jared |
Lo-Fi Version | Time is now: 12th May 2024 - 04:26 AM |
