Chrome Rear Bumper Top Fitting, Stud in Center |
Mowog4 |
Feb 13 2017, 05:29 AM
Member Group: Members Posts: 285 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
Hi
I am installing the rubber bumper top on a pre-73 bumper, there is a stud in the center that appear to not be attached to anything. I saw mention of a mounting tab, but have been unable to find a listing for one. Any help is appreciated. |
cary |
Feb 13 2017, 06:12 AM
It's welded to the earlier taillight panel.
Mark Henry |
Feb 13 2017, 07:22 AM
Is that the back of your car in your avatar?
Looks like someone removed/cut off the little tab/bracket that sticks out and that's where the center bolt goes. It would have been welded to the underside of the bumper recess. I'd fab up a bracket, drill a couple of holes and mount it. I know sucks, but you'll have to do something, it's the only support the pad has in the center. |
Mowog4 |
Feb 13 2017, 02:03 PM
Is that the back of your car in your avatar? Looks like someone removed/cut off the little tab/bracket that sticks out and that's where the center bolt goes. It would have been welded to the underside of the bumper recess. I'd fab up a bracket, drill a couple of holes and mount it. I know sucks, but you'll have to do something, it's the only support the pad has in the center. That is the back of my car, luckily the fear of drilling into the new paint has long left me. Any pictures of what the bracket should look like? Ed |
steuspeed |
Feb 13 2017, 02:22 PM
Senior Member Group: Members Posts: 1,005 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Bumper top tab.
Attached thumbnail(s) |
colingreene |
Feb 13 2017, 06:22 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
I drilled mine with paint on it, its not the end of the world to do it, i bolted the bracket to the bumper top then marked where the holes needed to go and drilled once i removed the tabs.
I used seam sealant between the parts and a large gauge pop rivet with a washer on the back to hold it on. Without it the center of the bumper top sags and looks terrible. My car being a 76 I had no idea that it was there so i was somewhat in the same boat you are. Its easy enough to do, dont panic. |
Mowog4 |
Feb 13 2017, 06:27 PM
I drilled mine with paint on it, its not the end of the world to do it, i bolted the bracket to the bumper top then marked where the holes needed to go and drilled once i removed the tabs. I used seam sealant between the parts and a large gauge pop rivet with a washer on the back to hold it on. Without it the center of the bumper top sags and looks terrible. My car being a 76 I had no idea that it was there so i was somewhat in the same boat you are. Its easy enough to do, dont panic. Did you cut a bracket off of another car or just fab one up? Thanks, Ed |
branston |
Feb 13 2017, 09:28 PM
Member Group: Members Posts: 89 Joined: 17-October 12 From: Michigan Member No.: 15,053 Region Association: Upper MidWest |
boxstr |
Feb 13 2017, 09:42 PM
Ed, good evening I may have a tab at CAMP, I will check tomorrow.
Craig at CAMP |
Mowog4 |
Feb 14 2017, 01:52 AM
colingreene |
Feb 14 2017, 02:27 AM
I think i got my tab from Bruce Stone
Lo-Fi Version | Time is now: 28th April 2024 - 02:25 AM |
