FS: 914 parts, Webers, distributors, Fuchs, engine tin, window glass, blowers, ect |
rwfms |
Feb 15 2017, 10:38 PM
Newbie Group: Members Posts: 17 Joined: 4-January 06 From: Wichita, KS Member No.: 5,365 |
Garage reduction sale. Most parts from '73 1.7or a '76 914. More photos available by request. PMs welcome . Located in Derby KS 67037 (Wichita). Buyer pays shipping. Many other 914 parts later.
1. Weber 40 IDF setup.----$360 SOLD Purchased new. Worked well on my ‘73 1.7 until engine broke, did a 6 conversion instead. Carbs are in very good condition with no play in the butterfly shafts. Made in ?? On the shelf about 10 years, will need rebuild kits and air filter elements. 3. 009 distributor for dual carbs----$50 4. 050 Distributor for dual carbs----$50 SOLD 5. Bosch stock 1.7 vacuum advance distributor ----$25 6. 5-lug Fuchs replicas, steel stems, very nice set. (2) 7x15, (2) 8x15 ----$400 SOLD 7. ’73 1.7 engine tin – ten pieces . Solid, straight, surface rust, no rot----$35 SOLD 8. Heat exchanger heater ducts – six pieces ----$35 9. Heat exchangers – pair ----$30 SOLD 10. Exhaust pipe & muffler, good condition, nice sound ----$35 SOLD 11. Exhaust pipe & muffler – rough ----$10 12. Motor Mount cross bar only ----$25 SOLD 13. Rubber motor mounts – pair ----$15 SOLD Both 12. and 13 ----$35 SOLD 14. Engine bay Blower, very good ----$35 SOLD 15. Engine bay blower, good motor and fan, loose fan shaft bearing ----$10 SOLD Both blowers ----$40 SOLD 16. Firewall sound deadener blanket, nice condition ----$30 SOLD 17. Rear luggage pad and floormat ----$25 ea. $45 both SOLD 19. Window glass set from ‘72 914, no windshield. Exceptional condition ----$85 L&R tinted window glass SOLD L&R tinted vent glass SOLD 1 clear back glass 20. Other window glass, original VW/Porsche 1 early clear driver side window w/bracket ----$25 1 late clear passenger side window w/brackets ----$25 1 clear back glass ----$25 1 NOS tinted L front vent glass w/original brackets, rubber seal and manufacturer’s label. Still has some rubber protectant goo on the seals ---$40 21. Trailing arm stiffener plates – pair ----$50 SOLD Attached image(s) |
N_Jay |
Feb 15 2017, 11:15 PM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
How well did those wheels work?
Spacers? Tire size? Did you have to flair at all? |
rwfms |
Feb 16 2017, 01:16 PM
How well did those wheels work? Spacers? Tire size? Did you have to flair at all? N Jay, these would be more for a flared car. I'm not an expert on clearances but I know guys who have put 7 inchers on the rear by bowing the fenders out slightly. Not sure if you could do the same in the front but the 8 inchers definitely wouldn't work. I am running wider wheels with flared quarter panels and I didn't use these on my car. Thanks for your interest. |
Lo-Fi Version | Time is now: 5th May 2024 - 03:26 AM |
