WTB fuel tank sensor, VDO 901.741.801.00 |
fixer34 |
Feb 19 2017, 03:46 PM
Senior Member Group: Members Posts: 1,075 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Since my sensor seems to indicate I have a 'bottomless' 1/4 fuel level, I need a replacement. Checked the resistance values and it's definitely not correct.
Would prefer the part number above, a late '69 or early '70 date code would be nice so it matches the car. (early '70 -6) |
boxstr |
Feb 19 2017, 04:14 PM
I can check later today at CAMP 914 to see if I have that part number available.
Craig at CAMP |
boxstr |
Feb 20 2017, 01:47 PM
Checked my supply and did not find the one you want, sorry.
Craig a CAMP |
bdstone914 |
Feb 20 2017, 03:03 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have one with a 6/70 date code. I may have more/ You can also swap the top ring from yours which is where the date code is stamped to a replacement unit. $75 plus shipping from 92505 CA Bruce |
euro911 |
Feb 20 2017, 08:59 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Just an FYI, they can be disassembled and cleaned up. The float might be stuck on some crud.
fixer34 |
Feb 21 2017, 05:21 PM
Just an FYI, they can be disassembled and cleaned up. The float might be stuck on some crud. Float seems to be moving fine. I tip it upside down, can hear the float 'bounce' against the top and the gauge shows 4/4 Full. Turn it right side up, float 'bounces' off the bottom. Warning light comes on, but gauge shows 1/4. Resistance check gives 67 ohms when 'empty', should be around 90 I understand. So I'm guessing it is something with the internal resistive wire. Probably just spend the $85 to get a replacement. It's worth that to not have to call the wife to bring me the gas can again... |
Beebo Kanelle |
Feb 25 2017, 02:53 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
soak it in vinegar
right side up for 2 hours / upside down for 2 hours - dissolves the crud |
Lo-Fi Version | Time is now: 26th April 2024 - 12:18 AM |
