QUOTE(euro911 @ Feb 20 2017, 08:59 PM)
Just an FYI, they can be disassembled and cleaned up. The float might be stuck on some crud.
Float seems to be moving fine. I tip it upside down, can hear the float 'bounce' against the top and the gauge shows 4/4 Full. Turn it right side up, float 'bounces' off the bottom. Warning light comes on, but gauge shows 1/4. Resistance check gives 67 ohms when 'empty', should be around 90 I understand. So I'm guessing it is something with the internal resistive wire.
Probably just spend the $85 to get a replacement. It's worth that to not have to call the wife to bring me the gas can again...
