WTB fuel tank sensor, VDO 901.741.801.00 |
fixer34 |
Feb 19 2017, 03:46 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Since my sensor seems to indicate I have a 'bottomless' 1/4 fuel level, I need a replacement. Checked the resistance values and it's definitely not correct.
Would prefer the part number above, a late '69 or early '70 date code would be nice so it matches the car. (early '70 -6) |
euro911 |
Feb 20 2017, 08:59 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Just an FYI, they can be disassembled and cleaned up. The float might be stuck on some crud.
fixer34 |
Feb 21 2017, 05:21 PM
Just an FYI, they can be disassembled and cleaned up. The float might be stuck on some crud. Float seems to be moving fine. I tip it upside down, can hear the float 'bounce' against the top and the gauge shows 4/4 Full. Turn it right side up, float 'bounces' off the bottom. Warning light comes on, but gauge shows 1/4. Resistance check gives 67 ohms when 'empty', should be around 90 I understand. So I'm guessing it is something with the internal resistive wire. Probably just spend the $85 to get a replacement. It's worth that to not have to call the wife to bring me the gas can again... |
Lo-Fi Version | Time is now: 26th May 2024 - 06:09 PM |
