Need 914/6 Throttle Bell Crank, An alternate source? |
gcrotvik |
Feb 20 2017, 05:39 PM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I need a throttle bell crank for my 914/6 trans/6 conversion. I have one but it's bent and pretty much worn out. I looked on the Mittelmotor site but came up empty. I put a WTB in the classified section several months back but no answer (as expected!)
Does anyone know of an alternate source for part number 91442302501? Thanks, Greg |
Dave_Darling |
Feb 20 2017, 06:03 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Do you need the original part? I believe that Rich Jonson (a914guy) makes a functional replacement, but I'm not sure how exact a replacement it is. Shoot him a PM and ask.
--DD |
IronHillRestorations |
Feb 20 2017, 06:10 PM
I. I. R. C. Group: Members Posts: 6,714 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Rich Johnson has made those in the past, I'm not sure if he still does
gcrotvik |
Feb 20 2017, 06:21 PM
Thank you both!
Greg |
914Sixer |
Feb 20 2017, 06:51 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Double check with Porsche. I think they had some made up.
Mark Henry |
Feb 20 2017, 06:55 PM
Is this for a real six trans? with the pin already on the case?
I believe RJ's is for a conversion of a /4, the bell crank might not fit. You can take a 911 bell crank which is correct except for the arm isn't in the right spot. It's brazed on so if you're careful you can heat it cherry red hot, then quickly spin it to the correct orientation. |
mepstein |
Feb 20 2017, 08:11 PM
914-6 GT in waiting Group: Members Posts: 19,240 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I used an RJ conversion with an intermediate plate from a 911. Works great. Fits on the stock stud. Rich's piece does come with an adaptor so it bolts on to a 914 case without mods.
Attached thumbnail(s) |
gcrotvik |
Feb 21 2017, 10:42 AM
gcrotvik |
Feb 21 2017, 10:45 AM
Is this for a real six trans? with the pin already on the case? I believe RJ's is for a conversion of a /4, the bell crank might not fit. You can take a 911 bell crank which is correct except for the arm isn't in the right spot. It's brazed on so if you're careful you can heat it cherry red hot, then quickly spin it to the correct orientation. It's for a real 914/6 trans that has the boss in the intermediate plate. Good suggestion on modifying the 911 bell crank. |
forrestkhaag |
Feb 21 2017, 02:08 PM
I just installed the RJ assembly and it is a perfect fit. Easy install as well. And yes, he has them for sale among other finely crafter conversion parts.
Cheers |
SirAndy |
Feb 21 2017, 02:16 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Adding another alternative to the mix, PMS makes a longer throttle cable for /6 conversions that doesn't need the linkage at all.
It simply loops around and goes straight to the throttle body. I used this for my 3.6L ... (IMG:style_emoticons/default/bye1.gif) |
SirAndy |
Feb 21 2017, 02:30 PM
Adding another alternative to the mix, PMS makes a longer throttle cable for /6 conversions that doesn't need the linkage at all. It simply loops around and goes straight to the throttle body. I used this for my 3.6L ... (IMG:style_emoticons/default/bye1.gif) You can see the black throttle cable to the right looping up through the opening in the sheet metal and to the throttle body. (IMG:style_emoticons/default/driving.gif) (IMG:http://www.914world.com/bbs2/uploads/post-179-1185423324.jpg) |
raynekat |
Feb 22 2017, 01:34 PM
Advanced Member Group: Members Posts: 2,154 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Found this nice piece just today on Ebay.
The curved throttle linkage from the bell crank up to the engine. http://www.ebay.com/itm/New-Genuine-Thrott...SWF&vxp=mtr |
mepstein |
Feb 22 2017, 03:17 PM
Found this nice piece just today on Ebay. The curved throttle linkage from the bell crank up to the engine. http://www.ebay.com/itm/New-Genuine-Thrott...SWF&vxp=mtr I think they sell for less from others. |
raynekat |
Feb 22 2017, 03:33 PM
Checked with my local dealer....only $45. So Ebay not a great deal.
bdstone914 |
Feb 22 2017, 09:35 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have several 911 ones that could be modified to make them into 914-6 ones.
1TRICK6 |
Feb 24 2017, 06:18 PM
Newbie Group: Members Posts: 45 Joined: 13-July 11 From: Southern California Member No.: 13,313 Region Association: Southern California |
Lo-Fi Version | Time is now: 27th April 2024 - 02:27 PM |
