Need 914/6 Throttle Bell Crank, An alternate source? |
gcrotvik |
Feb 20 2017, 05:39 PM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I need a throttle bell crank for my 914/6 trans/6 conversion. I have one but it's bent and pretty much worn out. I looked on the Mittelmotor site but came up empty. I put a WTB in the classified section several months back but no answer (as expected!)
Does anyone know of an alternate source for part number 91442302501? Thanks, Greg |
Mark Henry |
Feb 20 2017, 06:55 PM
Is this for a real six trans? with the pin already on the case?
I believe RJ's is for a conversion of a /4, the bell crank might not fit. You can take a 911 bell crank which is correct except for the arm isn't in the right spot. It's brazed on so if you're careful you can heat it cherry red hot, then quickly spin it to the correct orientation. |
gcrotvik |
Feb 21 2017, 10:45 AM
Is this for a real six trans? with the pin already on the case? I believe RJ's is for a conversion of a /4, the bell crank might not fit. You can take a 911 bell crank which is correct except for the arm isn't in the right spot. It's brazed on so if you're careful you can heat it cherry red hot, then quickly spin it to the correct orientation. It's for a real 914/6 trans that has the boss in the intermediate plate. Good suggestion on modifying the 911 bell crank. |
Lo-Fi Version | Time is now: 12th May 2024 - 02:13 AM |
