registering a 75 as a 74 in ca |
tod914 |
Jun 29 2003, 11:03 AM
there is a slight chance i might be moving los angelas. the build date on my 75 is 11/74. I would like to take the car with me if i move. I do not however want to cat it, smog it, and air pump it. Is it possible to register it as a 74?
swood |
Jun 29 2003, 11:09 AM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
No, becuase it IS a '75. Just non-op it till early next year and see if our '75's roll of the smog list. I think it's likely...but I don't hear that fat lady singing yet.
Jeffs9146 |
Jun 29 2003, 07:41 PM
You could fudge and buy a 74 roller the same color and use the plates!!..................did I say that!! No that wasnt mmmmmeee!!
Jeff |
garyh |
Jun 29 2003, 08:26 PM
Member Group: Members Posts: 170 Joined: 8-January 03 From: San Mateo, CA Member No.: 114 |
Time to bug everyone on the list about about SB708 again.
There is a bill in the California Senate to roll the smog exemption back to 1960 You read that right: nineteen-sixty. one-nine-six-zero. Which means each and every 914 in CA will either need to get smogged, of get "historic car" plates. Have -you- called your representatives to complain? |
Joe Bob |
Jun 29 2003, 08:42 PM
QUOTE(garyh @ Jun 29 2003, 06:26 PM) Time to bug everyone on the list about about SB708 again. There is a bill in the California Senate to roll the smog exemption back to 1960 You read that right: nineteen-sixty. one-nine-six-zero. Which means each and every 914 in CA will either need to get smogged, of get "historic car" plates. Have -you- called your representatives to complain? Historic plates don't get you off on smog checks....they can be had for 25 year old cars....smog is a rolling 30 year old exemption. |
EdwardBlume |
Jun 30 2003, 12:57 AM
Try and pass smog unless you don't think you can. If you don't pass, take it to a judge and fight it.
tod914 |
Jun 30 2003, 07:07 AM
Ok with that said. Is there any1 in CA whom passed smog with a 75-76 2.0 that isnt smogged, cat-ed-ed, or has an air pump on????? (IMG:style_emoticons/default/headbang.gif)
swood |
Jun 30 2003, 08:05 AM
It most likely won't pass the visual test with missing "smog" equipment. That's just the way it goes...
Jeffs9146 |
Jun 30 2003, 08:47 AM
Do a preliminary test and DO NOT have it sent to DMV via the smog station! If it is labled a gross poluter you will have to jump through hoops to get it fixed!
Jeff |
scotty |
Jun 30 2003, 08:52 AM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
Does a 49-state car have to meet CA rules if you move there (Example: 49-state 914 1.8 had no cat, no air pump... would the owner have to install said equipment when it didn't even come on the car from the factory)? (IMG:style_emoticons/default/unsure.gif)
If so, that REALLY sucks! (IMG:style_emoticons/default/mad.gif) |
rhodyguy |
Jun 30 2003, 08:53 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,076 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i don't know about cal rules. if the cat has been removed, you could be in for a nightmare. how long could you get away with jersey plates in cal if you were there on a "temporary" basis?
kevin |
tod914 |
Jun 30 2003, 09:09 AM
Thats what I was thinking Kevin. Our state inspections are good for 2 years. Registration is done on an annual basis. So, without getting a cali drivers license, in theory 2 years from the date I last have it inspected. Im pretty sure my insurance company would have some problems with that.
rhodyguy |
Jun 30 2003, 09:21 AM
so get a dupe nj d.l. drive home every 2 yrs for inspection. so what if you're on a "vacation" in cal. that's what you tell the ins co.
kevin |
ninefourteener |
Jun 30 2003, 09:53 AM
Perfectly Normal Guy :) Group: Members Posts: 1,216 Joined: 3-June 03 From: St. Louis, MO Member No.: 779 |
Of course..... you can always "fake" the smog test.
Run it to 1/4 tank.... drop in 2 bottles of Dry Gas, dive 5 miles, run it through the smog test, then fill up the tank immediately afterwards. A couple years back, I managed to get my Big-block El camino with straight pipes to burn cleaner than a Honda civic--LOL The inspector looked at me a bit funny, but it passed. Just a thought.... (IMG:style_emoticons/default/smile.gif) |
efrenv |
Jun 30 2003, 09:54 AM
Newbie Group: Members Posts: 35 Joined: 11-February 03 From: Claremont, California Member No.: 297 |
I had my 76 2.0 smog checked last year. It passed the emissions test but failed the "visual" when the smog pump did not work (not rotating-broken bottom pulley shaft) (IMG:style_emoticons/default/wacko.gif) . Epoxied the rubber coupling at the bottom pulley connecting to the fan housing (IMG:style_emoticons/default/wink.gif) , took it back for smog check the second time and passed. It appears that the computer print-out has all the smog emissions devices that are supposed to be part of the car and the smog mechanic knows what device to look for. Good Luck (IMG:style_emoticons/default/driving.gif) .
GWN7 |
Jun 30 2003, 10:00 AM
What is "Dry Gas"?
garyh |
Jun 30 2003, 10:14 AM
QUOTE(mikez @ Jun 29 2003, 06:42 PM) smog is a rolling 30 year old exemption. Pay attention, bright-eyes; "they" are trying to eliminate the 30-year rolling exemption, and move the 'grandfather' date back to 1960. Here. Read this: SB 708 Sheesh. Where did you say your day job was? |
ninefourteener |
Jun 30 2003, 10:22 AM
QUOTE(GWN7 @ Jun 30 2003, 08:00 AM) What is "Dry Gas"? Not exactly sure... I think it is pretty much just alcohol...but don't quote me on that. You can buy it at any cheezy auto parts store..... it's actually called "dry gas".... comes in a blue bottle (at least the stuff I bought did), and is in the section with all the fuel and oil additives. |
rhodyguy |
Jun 30 2003, 11:09 AM
so in cal, even if you meet the sniff test and aren't over polluting, you fail the visual, the pooch is screwed? no wonder i had to pay $2.23 for mid range gas 2 weeks ago in trinidad.
kevin |
garyh |
Jun 30 2003, 01:37 PM
QUOTE(rhodyguy @ Jun 30 2003, 09:09 AM) so in cal, even if you meet the sniff test and aren't over polluting, you fail the visual, the pooch is screwed? In California, you must pass the visual -first-. The sniffer test comes after. And FWIW, "NLA" is not a valid reason to not have the part on your car. (I have seen then require smog equipment that, according to documentation from the car maker, never existed.) |
Lo-Fi Version | Time is now: 12th May 2024 - 02:49 AM |
