GC or GA case? |
GC or GA case? |
mtndawg |
Feb 23 2017, 01:54 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
I have a '75 2.0L car and just took a GA engine out of it. I think GA was used for that year? Please correct me if I'm wrong. I also have a GC case. Is there a big difference between the cases?
Tom_T |
Feb 23 2017, 01:57 PM
Nope - it's a transplant, & your car could've originally been a 1.8 or 2.0, which you won't know without documentation or from a COA.
GA - 73-74 GC - 75-76 914 Info link at the top right of every page on here is your friend! (IMG:style_emoticons/default/smile.gif) http://www.914world.com/specs/engnumbs.php PS - the cases were basically the same, but there are some differences - as the GC was detuned & used a Crapalytic Converter for CA, so the 2.0 turned out less HP either way CA (least) or 49 state. The chart at the link above says 95 vs 88 HP, but IIRC from when I test drove a new 75 & 76 in 1975 before deciding on my 73 2L - the CA detuned 2L was only 86 HP due to the added CAT. PSS - If you can prove the car was a factory 2.0, then you may want to use the GC motor so that it's close to correct - especially if the case number/motor was originally in that 914 - making it a numbers matching car. If it's a converted 1.8, then you could use either - probably the one in best condition, & you may want to consider making it a 2056 (talk to McMark at Original Customs on that - see his banner ad). Stay dry up there! (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 20th May 2024 - 06:54 PM |
