Another seat installation question ( aluminum ) |
FastFroggy |
Feb 25 2017, 02:36 PM
Newbie Group: Members Posts: 36 Joined: 27-November 15 From: Ann Arbor MI Member No.: 19,415 Region Association: Upper MidWest |
Working my seat installation... I'm happy with the base mounts
(IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-19415-1488067033.1.jpg) but struggling with the back support.. (IMG:http://www.914world.com/bbs2/uploads_offsite/img.photobucket.com-19415-1488067033.2.jpg) Problem is that there really is not any space to even put your hands in let alone mark you spot. But my basic question: which is preferred and why? a. Should belt and seat back mount to firewall. b. Should belt and seat back mount to roll bar ( i prefer this but I cannot figure a way to do this given the space available.). c. Should belt to fire wall and seat back mount to roll bar. d. Should belt to roll bar and seat back mount to firewall. Please note that I have an eight paint roll cage. |
wndsrfr |
Feb 28 2017, 09:52 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
If you're racing you'll need to find out the rules about seat support. I'm doing DE events only & don't have the seat back supported, just the base. Belts are clipped to eye bolts through bolted to reinforcing plates welded on the back side of the firewall...so the belts hold me and the seat in place I guess.
ThePaintedMan |
Mar 1 2017, 11:04 AM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
(IMG:style_emoticons/default/agree.gif) - rules vary per organization. However, I should note something that I feel is important. Unless the seat is specifically designed to be stand-alone with good side-mounts, i.e. most FIA-rated carbon seats, a proper seat back support should really be a consideration. Belts were designed to restrain the driver, but not the movement of a seat and driver combined. On an AX car, no biggie, but on the track, the speeds and forces are much, much greater in the event of an accident. I do believe that Kirkey specifically recommends a seatback brace with their seats as well.
brant |
Mar 1 2017, 03:58 PM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Here is the seat back brace we made 12 years ago
it passed pca club racing tech back in the day Attached image(s) |
Cracker |
Mar 2 2017, 09:43 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
I welded a plate on the cage behind my Kirkey...together with the base mounted, it is the strongest installation I have ever felt. My belts are installed around the cage too. Definitely find out what the minimum requirements are but if it is allowed - pin the seat high (somehow).
PS: Nice brace Brant...its been awhile - I hope you are well. T |
ge9146 |
Mar 4 2017, 10:29 AM
Newbie Group: Members Posts: 47 Joined: 5-March 05 From: Western Michigan Member No.: 3,716 Region Association: Upper MidWest |
I would also agree to start with the rule book for the racing group or groups that you intend to run with. It will save you lots of grief when you go thru tech inspection for the first time. The rule books usually have some guidelines for belt attachment that can be helpful. Simpson safety equipment and Schroth equipment have some good guidelines on their site for belt location, attachment and angles. I have helped out in tech inspection in the past and it sometimes pays to do some research early on to save your self some issues at tech later.
Simpson seatbelt installation Schroth Be safe and Have Fun! PS: Take a serious look at a HANS device or equivalent too! |
sixaddict |
Aug 10 2017, 06:57 PM
Senior Member Group: Members Posts: 799 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Two questions:
1. Do brackets mount to stock sliders 2. Are they adjustable...l.e.can seat be moved back or forward Thanks |
FastFroggy |
Aug 12 2017, 03:03 PM
I ended up mounting the belts per the bet manufacturer.
Mine are hard mounted. Sliders are generally not legal to race. |
Lo-Fi Version | Time is now: 28th April 2024 - 11:46 AM |
