Should I rip up my tar boards., What's the best way? |
Teen Hulk |
Feb 26 2017, 10:47 AM
Newbie Group: Members Posts: 11 Joined: 9-April 16 From: Port Hope, Ontario, Canada Member No.: 19,880 Region Association: Canada |
My floors look good, do I have to rip up the tar boards and what is the best way?
Attached thumbnail(s) Attached image(s) |
iankarr |
Feb 26 2017, 07:29 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
What do you guys think about removing tar on highly original cars?
I don't meant to hijack the thread, but I pulled a piece of tar in a spot likely to breed rust and it was clean. Would you sacrifice originality to prevent future rust? |
KELTY360 |
Feb 26 2017, 08:01 PM
914 Neferati Group: Members Posts: 5,034 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
What do you guys think about removing tar on highly original cars? I don't meant to hijack the thread, but I pulled a piece of tar in a spot likely to breed rust and it was clean. Would you sacrifice originality to prevent future rust? What does your hell hole and longs look like? Is the firewall insulation pad in the engine bay intact? Does the rear window show any signs of being resealed? Is it still tight? I'd inspect all potential areas of rust inside and out before making the decision to tear up the tar. Use your best judgement at that point. |
iankarr |
Feb 26 2017, 08:34 PM
What do you guys think about removing tar on highly original cars? I don't meant to hijack the thread, but I pulled a piece of tar in a spot likely to breed rust and it was clean. Would you sacrifice originality to prevent future rust? What does your hell hole and longs look like? Is the firewall insulation pad in the engine bay intact? Does the rear window show any signs of being resealed? Is it still tight? I'd inspect all potential areas of rust inside and out before making the decision to tear up the tar. Use your best judgement at that point. Hell hole and longs are great. Firewall insulation pad is intact. No signs of rust on either side of the firewall. Even with a scope I snaked behind the pad. My guess is that, if there's rust under the tar, it's probably minimal. For now, I'm erring on the keep it original side, but I'm open to other opinions... Thanks! |
Lo-Fi Version | Time is now: 28th May 2024 - 02:58 AM |
