Garage Clean Out, Mostly type 4 |
eric914 |
Feb 26 2017, 03:15 PM
Member Group: Members Posts: 381 Joined: 28-January 04 From: Waynesville OH Member No.: 1,613 Region Association: Upper MidWest |
[/s]European Motor works 054-106H cam new $150 / sell $105 European Motor Works cam gear new $40 / sell $28 More to follow Attached thumbnail(s) |
eric914 |
Feb 26 2017, 03:19 PM
More photos
eric914 |
Feb 26 2017, 03:22 PM
last set
eric914 |
Feb 26 2017, 03:23 PM
photos
914forme |
Feb 26 2017, 04:02 PM
Fuel Pump. low pressure unit? If so I'll take it.
KevinW |
Feb 26 2017, 04:20 PM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
What size is the oil pump?
Thanks, Kevin |
eric914 |
Feb 26 2017, 04:30 PM
26mm gears.
From their website - Maxi Pump 1 - The Maxi Pump 1 is the perfect oil pump for street, off-road and competition. The die cast blue-printed housing features a "pressure chamber" to help provide a constant flow of oil. The added volume and anti-cavitation features of the Maxi 1 make it the top choice for use with external oil cooler and filter systems. The Maxi 1 slips right in to replace your stock oil pump. Fuel pump is low pressure for carbs. |
914forme |
Feb 26 2017, 05:14 PM
(IMG:style_emoticons/default/piratenanner.gif) I'll take it. I can pickup as I used to spend bunch of time in your town.
Keith914 |
Feb 26 2017, 05:29 PM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
Jett |
Feb 26 2017, 05:37 PM
Senior Member Group: Members Posts: 1,637 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
I'll take the hardware kit, if available.
Please PM shipping to 98073 Cheers |
two-strokejohn |
Feb 26 2017, 06:15 PM
Member Group: Members Posts: 81 Joined: 30-March 06 From: Orient, Ohio Member No.: 5,793 Region Association: North East States |
I'll take the gasket set, pushrod tubes, cam bearing set.... please send total and payment info
area code 43146 in Orient, oh |
echocanyons |
Feb 26 2017, 07:24 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I would like the p&cs and cam please
The cam looks like it's for carbs so I'll pass on this. I will rake the rings and bearings though |
echocanyons |
Feb 26 2017, 07:26 PM
I'll take the lifters, springs and pushrod tubes as well
rfinegan |
Feb 27 2017, 04:52 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I will take the rocker spacer kit (PM sent)
Robert |
Gint |
Feb 27 2017, 06:55 AM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I'll take this:
weber IDF update kit 40mm new $135 / sell $95 Shipping to 80602. Please also let me know your payment preference. PP works for me. |
eric914 |
Feb 27 2017, 11:22 AM
Just what is in the article i posted. i have no direct experience.
photos I have weber 44"s so can't use your Weber Update kit By CB Performance. This kit looks very interesting -- do you have any comments as to its' effectiveness? |
eric914 |
Feb 27 2017, 11:35 AM
Ill send everyone a PM tonight when i get home with shipping info. Lunch just few by today:(
MartyYeoman |
Feb 27 2017, 02:13 PM
Senior Member Group: Members Posts: 1,517 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
I'd be interested in the pushrod set and length adjustment tool. Shipping to 94583.
Thanks, Marty PM sent. Attached image(s) |
KevinW |
Feb 28 2017, 06:00 AM
26mm gears. From their website - Maxi Pump 1 - The Maxi Pump 1 is the perfect oil pump for street, off-road and competition. The die cast blue-printed housing features a "pressure chamber" to help provide a constant flow of oil. The added volume and anti-cavitation features of the Maxi 1 make it the top choice for use with external oil cooler and filter systems. The Maxi 1 slips right in to replace your stock oil pump. Fuel pump is low pressure for carbs. PM sent for oil pump |
eric914 |
Mar 1 2017, 11:29 AM
i think i have send a PM to everyone with shipping info.
The Cam and the cam gear are still available. The cam was selected by European Motor Works based on a 1911cc build with carbs. If someone is interested in the cam and the cam gear as a sell ill sell the pair for $125 including shipping within the US. |
Lo-Fi Version | Time is now: 2nd May 2024 - 01:18 PM |
