Left defroster...., no hot air.... ???? |
BuddyV |
Feb 28 2017, 09:47 PM
Robert Group: Members Posts: 555 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
New-to-me 914 gets warm air on the RIGHT side windsheild defroster when I pull the red lever below the shifter.....
but the lefft does not seem to get warm at all. Where should I start looking for a fix, typically? Cheers. (IMG:style_emoticons/default/beerchug.gif) |
Mikey914 |
Mar 1 2017, 12:37 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Check the hoses. The factory ones are notoriously flimsy. Possibly just detached. If not check the wires to the diverters. These control where the air goes. From your description I would suspect the hose.
Also if you need them I have more robust ones here - http://shop.914rubber.com/Hoses-from-blowe...f-2-914HHLD.htm Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:31 PM |
