New-to-me 914 gets warm air on the RIGHT side windsheild defroster when I pull the red lever below the shifter.....
but the lefft does not seem to get warm at all.
Where should I start looking for a fix, typically?
Cheers.
Mikey914
Mar 1 2017, 12:37 AM
Check the hoses. The factory ones are notoriously flimsy. Possibly just detached. If not check the wires to the diverters. These control where the air goes. From your description I would suspect the hose.
Also if you need them I have more robust ones here -
