fuel pressure regulator, Carb. Ideal PSI |
80cap |
Mar 2 2017, 01:28 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
What is the best psi for a carb setup? I already have a low pressure pump but I read that it still might be to high.
Brian |
stugray |
Mar 3 2017, 08:03 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
One thing to keep in mind: If you are using pump gas with ethanol, it will likely kill the diaphragm in the cheap pressure regulators in just a year or two. Then the pressure no longer "regulates".
Lo-Fi Version | Time is now: 24th May 2024 - 12:56 PM |
