fuel pressure regulator, Carb. Ideal PSI |
80cap |
Mar 2 2017, 01:28 PM
Member Group: Members Posts: 317 Joined: 6-February 15 From: ohio Member No.: 18,405 Region Association: None |
What is the best psi for a carb setup? I already have a low pressure pump but I read that it still might be to high.
Brian |
Junebug |
Mar 2 2017, 08:07 PM
Newbie Group: Members Posts: 20 Joined: 7-May 15 From: East Bay Area NorCal Member No.: 18,713 Region Association: Northern California |
Depends on Carbs, I use a Holly at 2 psi for 10 mm ID line and dual Dellorto 40's
porschetub |
Mar 3 2017, 02:38 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Depends on Carbs, I use a Holly at 2 psi for 10 mm ID line and dual Dellorto 40's That's odd,I have the same regulator (12-804) and can't get 2psi its not in the range if the adjustment,anyway 2psi is low,I run 3.2psi and have no issues. I see in the pic your regulator is screwed right out ,not sure how you get 2psi....just asking (IMG:style_emoticons/default/dry.gif) . |
Lo-Fi Version | Time is now: 24th May 2024 - 02:19 PM |
