-6 Air filter bucket differences help |
mb911 |
Mar 7 2017, 07:55 AM
914 Guru Group: Members Posts: 6,856 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
So I have been working on restoring little parts along the way of my build. I have also collected the airfilter housing (stock) and the buckets for the carbs. I noticed after I sand blasted the parts and got them ready for plating and powdercoating that they are different slightly. The clips are of different sizes (length) and I can only assume that this is a difference between carb and MFI bases? any idea? Which is for what?
porschetub |
Mar 7 2017, 01:36 PM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
So I have been working on restoring little parts along the way of my build. I have also collected the airfilter housing (stock) and the buckets for the carbs. I noticed after I sand blasted the parts and got them ready for plating and powdercoating that they are different slightly. The clips are of different sizes (length) and I can only assume that this is a difference between carb and MFI bases? any idea? Which is for what? Not sure about the MFI ones but 2 clips on my carb bases were different and I found they were bent ,they are fairly springy steel but still bend back straight,did you find rust under the rubber sealing rings of the bases ? |
GeorgeRud |
Mar 7 2017, 01:45 PM
[quote name='mb911' date='Mar 7 2017, 05:55 AM' post='2461408']
So I have been working on restoring little parts along the way of my build. I have also collected the airfilter housing (stock) and the buckets for the carbs. I noticed after I sand blasted the parts and got them ready for plating and powdercoating that they are different slightly. The clips are of different sizes (length) and I can only assume that this is a difference between carb and MFI bases? any idea? Which is for what? [/quote I have a stock -6 and a MFI 911 at our cottage in Fontana, WI. However, I probably won't be able to get up there till springtime. If I do get up there, I'll try to measure the MFI cleaner bases for you, but the 914-6 is pretty well tucked away and inaccessible rill springtime. George |
mb911 |
Mar 7 2017, 03:11 PM
I found a little rust but not to much. They are getting powdercoated right now. There is a big difference in clip length probably an inch or so larger on the one bucket. My guess is that is for mfi. Mark said (whom I got them from) may have given me one of each but not sure if it is really just a clip thing or the buckets are actually different.
Lo-Fi Version | Time is now: 26th May 2024 - 08:52 AM |
