FS: Rear brake caliper $75 (pass side I think), rear brake caliper |
pSquared |
Mar 8 2017, 02:35 PM
Newbie Group: Members Posts: 7 Joined: 23-April 06 Member No.: 5,913 |
kkid |
Mar 11 2017, 02:41 PM
Member Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California |
It looks like a driver side to me. Correct me if I am wrong. The driver side is what I am looking for. Is the bonus rebuilt kit complete?
rjames |
Mar 11 2017, 05:08 PM
I'm made of metal Group: Members Posts: 3,920 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Looks like driver side to me too. IIRC, the connection to the ebrake is on the bottom. But maybe the photo is reversed?
If it's truly the passenger side I'll buy it. |
bdstone914 |
Mar 12 2017, 10:12 AM
bdstone914 Group: Members Posts: 4,515 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
PM sent
bcheney |
Mar 12 2017, 11:22 AM
Senior Member Group: Members Posts: 1,341 Joined: 16-November 03 From: Orlando, FL Member No.: 1,348 Region Association: South East States |
Here is what the drivers side looks like mounted on the car.
Attached thumbnail(s) |
pSquared |
Mar 12 2017, 08:09 PM
Sold.
Thanks, p2 |
GregAmy |
Mar 16 2017, 06:09 PM
Advanced Member Group: Members Posts: 2,283 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Hi gents. As Phillip noted, I've already cut the deal with him. However, I think you're correct: I think it's a left one, and of course I actually need a right. So let me look at it when it arrives in a day or so and it may be back up for grabs...
"bcheney", what's the story there in the caliper spacers to allow use of a vented rotor...? |
rgalla9146 |
Mar 17 2017, 06:04 PM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Hi gents. As Phillip noted, I've already cut the deal with him. However, I think you're correct: I think it's a left one, and of course I actually need a right. So let me look at it when it arrives in a day or so and it may be back up for grabs... "bcheney", what's the story there in the caliper spacers to allow use of a vented rotor...? 10 mm spacers harvester from M front calipers. longer bolts too trim rotor diameter a bit trim end of through tube on trailing arm for caliper clearance shim caliper off mounts to center it over rotor |
bcheney |
Mar 28 2017, 05:19 AM
Hi gents. As Phillip noted, I've already cut the deal with him. However, I think you're correct: I think it's a left one, and of course I actually need a right. So let me look at it when it arrives in a day or so and it may be back up for grabs... "bcheney", what's the story there in the caliper spacers to allow use of a vented rotor...? 10 mm spacers harvester from M front calipers. longer bolts too trim rotor diameter a bit trim end of through tube on trailing arm for caliper clearance shim caliper off mounts to center it over rotor Eric at PMB used to make what he called a V-Caliper kit to allow for you to retain an ebrake when converting to 5 lug on your teener. Not sure if he still makes them. Works great! My car is a -6 conversion. |
Lo-Fi Version | Time is now: 3rd May 2024 - 07:16 AM |
