'72 Horn button and contact ring |
amphiduck |
Mar 9 2017, 07:48 PM
Member Group: Members Posts: 94 Joined: 29-September 06 From: Tennessee Member No.: 6,947 |
Got some newbie questions on my '72, it's been so long I can't remember..does it use the short or long horn button? I have the long button and it won't go through the steering wheel contact, even with some elbow grease in twisting it through the opening. Also, where does the contact ring wire come through the steering wheel to attach to the contact tab on the horn pad?
Thanks for the help! Attached thumbnail(s) |
Mike Fitton |
Mar 9 2017, 07:58 PM
Senior Member Group: Members Posts: 609 Joined: 13-May 11 From: Chicago Area Member No.: 13,069 Region Association: Upper MidWest |
If it is a 914-4 then it takes the long one picture because of the long plastic hub on the back of the wheel.
Mar 9 2017, 08:01 PM
If it is a 914-4 then it takes the long one picture because of the long plastic hub on the back of the wheel. And no wire, that's for the later cars. Additionally, if you have a contact pad with the little metal tab for the wire, you have the wrong one. You can use that pad but you need a different ring. If that's the case, pm me your address and I'll send you the correct ring to switch on to your horn pad. The horn button should not require elbow grease to install. It should slide in easily. It's pretty fragile. |
amphiduck |
Mar 9 2017, 08:11 PM
It is indeed a 914-4. Just seems like I really have to jam that button down in there to fit through the hole. And looks like I'm in the market for an early turn signal cancellation ring.
Thanks for your help! |
Mar 9 2017, 08:35 PM
Like I said, pm me your address and I will send you one - free.
I'll be home from vacation Sunday night so it will go out Monday. No charge or obligation. I have a couple extra ones. Mark |
Mar 9 2017, 08:42 PM
I'm thinking more about this and your '72 takes a later wheel with a wired horn, not a horn button. The steering wheel model number should end in a 11.
Can you take a picture of the front of the steering column without the steering wheel? An early column has the large metal ring for the horn button to slide on. |
amphiduck |
Mar 9 2017, 08:44 PM
Like I said, pm me your address and I will send you one - free. I'll be home from vacation Sunday night so it will go out Monday. No charge or obligation. I have a couple extra ones. Mark Truly appreciate it, and I'll take you up on that horn ring. Now I'm wondering if I have the wrong steering wheel or what is going on. The car was some what of a hodge podge, but the title claims it to be a '72. The steering wheel is identical to my '74. Attached thumbnail(s) |
Mar 9 2017, 09:10 PM
Like I said, pm me your address and I will send you one - free. I'll be home from vacation Sunday night so it will go out Monday. No charge or obligation. I have a couple extra ones. Mark Truly appreciate it, and I'll take you up on that horn ring. Now I'm wondering if I have the wrong steering wheel or what is going on. The car was some what of a hodge podge, but the title claims it to be a '72. The steering wheel is identical to my '74. That's a later wheel. Let's see the steering column |
amphiduck |
Mar 10 2017, 05:17 PM
Like I said, pm me your address and I will send you one - free. I'll be home from vacation Sunday night so it will go out Monday. No charge or obligation. I have a couple extra ones. Mark Truly appreciate it, and I'll take you up on that horn ring. Now I'm wondering if I have the wrong steering wheel or what is going on. The car was some what of a hodge podge, but the title claims it to be a '72. The steering wheel is identical to my '74. That's a later wheel. Let's see the steering column Sorry for the delay. Here's a pic of the dash/steering column. Hopefully that tells a little more. Attached thumbnail(s) |
Mar 10 2017, 06:16 PM
That's a later column. You have the correct horn pad and wheel. I can't help you with the wire but I'm sure someone here or a proper diagram will help you with the wire connection.
amphiduck |
Mar 13 2017, 01:30 PM
That's a later column. You have the correct horn pad and wheel. I can't help you with the wire but I'm sure someone here or a proper diagram will help you with the wire connection. Thanks again for the help! Now I'm wondering if the later models even used the spring loaded push contact. With the plastic ring with the wire vs the metal ring on the earlier cars, I don't see how it would even work. |
GaroldShaffer |
Mar 13 2017, 02:07 PM
That's a later column. You have the correct horn pad and wheel. I can't help you with the wire but I'm sure someone here or a proper diagram will help you with the wire connection. Thanks again for the help! Now I'm wondering if the later models even used the spring loaded push contact. With the plastic ring with the wire vs the metal ring on the earlier cars, I don't see how it would even work. No they never did. |
Mar 13 2017, 02:33 PM
That's a later column. You have the correct horn pad and wheel. I can't help you with the wire but I'm sure someone here or a proper diagram will help you with the wire connection. Thanks again for the help! Now I'm wondering if the later models even used the spring loaded push contact. With the plastic ring with the wire vs the metal ring on the earlier cars, I don't see how it would even work. No they never did. As Garold said. You will need to figure out where the wire attaches and replace it. You cannot use the horn button with your column. |
Lo-Fi Version | Time is now: 18th May 2024 - 06:36 AM |
