Bosch rebuilt or High-Torque Starter, Which one to get. |
HansJan |
Mar 10 2017, 04:23 PM
Member Group: Members Posts: 394 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
Hello,
Having a starter issue. Ever since the charging system and electrical shorts have been worked out, the starter is cranking strong. However since this morning it is not cranking any more (just a loud "click"). hit the thing with a hammer (used to do the trick 25 yr ago, on the old Audi) but without success. So I'm shopping for a new starter. There are the Bosh rebuilds (at Pelican and AutoAtlanta) approx. $116. There is the High Torque starter from Performance Product (Pelican) $255. Car is a 1972 with 103mm cylinders (based on 2.0l case). In this matter I only care about reliability and durability. In the opinion of the 914World brain-trust, which starter is the one to get? |
OldMan |
Mar 20 2017, 07:50 PM
Newbie Group: Members Posts: 2 Joined: 10-September 16 From: Chattanooga, TN Member No.: 20,382 Region Association: South East States |
Are you sure that you don't have a grounding problem? This might be an electrical problem instead of a pure mechanical problem. As I understand, your starter doesn't turn at all?! You know these things are notorious for not starting. I am having that problem as we speak, but haven't redone my engine ground to the trunk floor in about 6 or 7 years, so I suspect that this is my problem. It might also be a battery grounding failure. Please understand that it takes only a very small grounding problem to upset the poorly designed Bosch starter solenoids. It might be yours as well.
Lo-Fi Version | Time is now: 3rd May 2024 - 11:55 PM |
