Grounding Stud Repair / Replacement |
db9146 |
Mar 13 2017, 09:13 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Has anyone found a source for the grounding stud on the passenger side engine compartment wall beside the battery? The PO sheared mine off like so
and I'm looking for something like this to replace it (Stanley Tucker Large Flange 8M stud). I figure I could use a bolt but looking for a better solution if possible. |
JFJ914 |
Mar 14 2017, 08:53 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
Has anyone found a source for the grounding stud on the passenger side engine compartment wall beside the battery? The PO sheared mine off like so and I'm looking for something like this to replace it (Stanley Tucker Large Flange 8M stud). I figure I could use a bolt but looking for a better solution if possible. I just drilled it out and welded in a bolt and ground off the hex. |
9fourteen14 |
May 27 2017, 06:24 PM
PORSCHE LUVA Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States |
Has anyone found a source for the grounding stud on the passenger side engine compartment wall beside the battery? The PO sheared mine off like so and I'm looking for something like this to replace it (Stanley Tucker Large Flange 8M stud). I figure I could use a bolt but looking for a better solution if possible. I just drilled it out and welded in a bolt and ground off the hex. Hi John, how are you? did you ever find anything more with the GROUNDING STUD? I am assuming that is the place everything is grounded to. is that correct? I need to check all my grounds.... make SURE they are all clean and contacting! so I might as well start at the source...... Tomorrow, (long weekend) I will start there and follow everything back from there. I would love a ground map? anybody every see or create a ground map? 914 luva |
Lo-Fi Version | Time is now: 12th May 2024 - 01:31 AM |
