4 Pages V  1 2 3 > »
> Money and motor options, What is a realistic budget and parts list
thelogo
post Mar 13 2017, 09:50 PM
Group: Retired Members
1st off the engine im going for in no way needs to
Be optimised for performance (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/stirthepot.gif)
What is the best combo for just cool reliable running
In socal heat .
Im trying to stay clear of d jet (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bootyshake.gif)
So carbs or i like cb performance f.i kit but know little actually about it .
What
Crank
Pistons
Rods
Cam
Cyclinder s
Fuel delivery
Etc should i be putting together and what kinda budget windfall
Should i be prepared for .
I know its a sickness but cant be that expensive?
I will use a machine shop to build the motor
That have extensive experience with type 4
So i know thats gonna cost me major $
(IMG:style_emoticons/default/pray.gif)
(IMG:style_emoticons/default/smoke.gif)
Talk to me about proven engine combinatios (IMG:style_emoticons/default/beer3.gif)
thelogo
post Mar 13 2017, 09:54 PM
Im looking for air cooled type 4
And basically the exact opposite of this
Mueller
post Mar 13 2017, 10:25 PM
914 Freak!
I think McMark does the 2056 for about $5k , don't think that includes the fuel delivery.
So figure another grand for for fuel and spark.
Dave_Darling
post Mar 13 2017, 10:29 PM
914 Idiot
A sock 1.7 should hold up just fine under darned near any circumstances you throw at it. If you want to avoid D-jet, stick some Dells on it. Maybe drop the compression to the lower 73 CA-only spec (about 7.6:1) so you don't have to run premium.
You said it wasn't about performance....
--DD
thelogo
post Mar 13 2017, 10:47 PM
QUOTE(Dave_Darling @ Mar 13 2017, 09:29 PM) *
--DD
Thats pretty much the setup im runnin now
1.7 d,jet not running correctly, may just be f.i related
But
Do i rebuild a separate 1.7 and swap in
Wait till my 1.7 breaks down then rebuild it
It it even worth it building a fresh 1.7 or does that cost the same as a 2056 ?
thelogo
post Mar 13 2017, 10:54 PM
QUOTE(Mueller @ Mar 13 2017, 09:25 PM) *
Thats a pretty doable budget i think
As long as its cheaper than a / 6 six
Chris914n6
post Mar 13 2017, 10:56 PM
Jackstands are my life.
Depends on what you are starting with.
66mm or 71mm crank?
1.7 block/heads or 1.8/2.0 b&h?
new or used carbs?
You can hit $10k pretty quick if you veer far enough away from stock.
I find a stock 2.0 pretty decent.
I'd ask the shop what they like and what they might have stashed in storage.
"socal heat" (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) My high today was your summer high average.
Larmo63
post Mar 13 2017, 10:57 PM
Look for a complete 2.0 core, tear it down to a long block and take it down to Jorge at EMW.
He can give you options, he's easy to work with, and you can do the tins, fan shroud, powder coating & painting yourself.
He takes CASH too.
I made payments to him.
My $.02
struckn
post Mar 14 2017, 08:45 AM
Most people won't get what I'm saying but here's where I'm at. In tune with KEEP IT SIMPLE STUPID, and I'm talking about me, not anyone else, we all have are own ideas, but I will say some get in over their heads trying to do it their self and dreaming of major improvements in a short period of time.
I have a '74 1.8 that came with a SIMPLE Single 2V Weber 32/36 Carb. Five years ago it dropped a Valve Seat so I took it to Translog GT for a complete mechanical inspection and overhaul resulting in installation of a new Carb Cam, (2) replacement Heads splitting the case new Bearings, Valve Seats, Fuel Pump, SS Fuel Lines, pulling the Trans axle New Clutch, Bearings, Shift linkage Bushings, Heat Billows replacement wiring and everything else that was needed to make it as dependable and as problem free as possible. In the last five years I have not had to make any adjustments, or replace any parts, other then an Oil and filter. The cost was around $5K with the understanding it would be a few months to allow them to get it done when convenient to the operation of their shop, and a pay as it goes terms. Documentation of Time and Material provided.
I'd have no concern driving it every day, or cross county.......except my 'Ol body in the car would probably fall apart before anything on the car would.
post Mar 14 2017, 09:02 AM
914-6 GT in waiting
Another option is a WTB request. Every year, many guys on this site convert to a six and sell their four. Many times the engine is in great running condition. It might not happen right away but it always happens. Dion just sold his. Ran like a top, looked great but he got 6 fever. I brought home a good running, complete with FI and tin, 2.0 from Virginia for a local 914 owner for $1,000. That was a no brainer.
When we were at Octeenerfest, Bob told me that half of the participants were not on 914world. I bought a great car from CA for $2,500 from the 914 yahoo group. So as big as 914world is, don't be afraid to reach out to other sources.
mgphoto
post Mar 14 2017, 09:39 AM
"If there is a mistake it will find me"
QUOTE(thelogo @ Mar 13 2017, 09:47 PM) *
--DD
But
sort out the d-jet your car should be worth more with FI than a single carb, which is the cheapest way to go.
Tom_T
post Mar 14 2017, 10:01 AM
TMI....
Since you're in SoCal ....
I'm not sure exactly when they were supposed to close, but you might try getting with Ron at FAT Performance in Orange before he retires, to both advise you on what to build, & to build it if there's enough time before he hangs up the wrenches.
FAT Performance has been building T-IVs since the came out in the late 1960s - for both street & competition - & many/most of the other engine builders learned from him.
If he can't build it for you, then he may be able to recco the best shop. Tuttle's in LA has been doing VW engine rebuilds for decades.
A 2.0 with Euro heads would give you a boost of HP & TQ over the stock GA 2.0 or 1.7, but you may need to bump to mid-grade or premium gas.
I don't know that going to carbs will solve your problem, as the D-jet EFI was a great system for those who knew how to tune them properly.
You my try Bill Brewster in South OC (San Clemente IIRC) or Der Buggy in Garden Grove to see if they can sort out your D-jet issue, before jumping to a new motor.
Bruce Stone/bdstone may also have a shop in the IE who knows T4 motors & D-jet.
PS - I think the optimal bore/stroke max on a 1.7 without compromising heat & driveablity is 1911cc.
Good Luck!
Tom
Dave_Darling
post Mar 14 2017, 10:58 AM
914 Idiot
I'd say wait until yours is on the way out. Or get a spare (core 1.7s should be cheap!) and build it as time and budget allow.
A 1.7 should be more reliable than a 2.0 or a 2056. They tend to be less stressed, have more robust rod journals, have heads that are less prone to cracking, and have less demanded of them.
--DD
thelogo
post Mar 14 2017, 04:41 PM
(IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/pray.gif)
Sound advice d.d
Im happy with a 1.7
Not happy with djet .
Mueller
post Mar 14 2017, 04:59 PM
914 Freak!
QUOTE(thelogo @ Mar 14 2017, 03:41 PM) *
Sound advice d.d
Im happy with a 1.7
Could be operator error (IMG:style_emoticons/default/smile.gif)
Any fuel system be it a single carb or even a $5,000 Motec system can give you fits if not in tip top shape and if you don't know how to work on it, you could spend $10K on a new motor with modern EFI or dual carbs and be miserable if not tuned correctly or you miss a simple vacuum line.
I'd go thru all the basic troubleshooting of the FI and ignition 1st as well as a full tune up.
thelogo
post Mar 14 2017, 06:40 PM
QUOTE(Mueller @ Mar 14 2017, 03:59 PM) *
Sound advice d.d
Im happy with a 1.7
Yeh anything is possible
But just to clarify i really never turn wrench s
On my cars
Im the driver " they told me to get in the car an drive an i could drive "
I leave the tune ups and maintenance to a professional air cooled guy with 40years experience.
But he refuses to deal with djet
So there i am (IMG:style_emoticons/default/poke.gif)
thelogo
post Mar 14 2017, 06:42 PM
[quote name='Mueller' date='Mar 14 2017, 03:59 PM' post='2464197']
[quote name='thelogo' post='2464191' date='Mar 14 2017, 03:41 PM']
Sound advice d.d
Im happy with a 1.7
[/quote]
How do you fuck up a single carb (IMG:style_emoticons/default/WTF.gif)
Mike D.
post Mar 14 2017, 07:03 PM
OK, It runs now, and pretty good too!
QUOTE(thelogo @ Mar 14 2017, 05:42 PM) *
You don't, it fucks you up. They are POS. And lose the mechanic that won't work on your car.
Take it to Leamon in Tajunga. PM him, he's HeelToe914
Mueller
post Mar 14 2017, 08:09 PM
914 Freak!
[quote name='thelogo' date='Mar 14 2017, 05:42 PM' post='2464233']
Sound advice d.d
Im happy with a 1.7
[/quote]
[/quote]
Easy, they are already not the best solution for our motors, but they can be made worse by tweaking the settings, some people shouldn't be allowed to own a screw driver! Lot's of car problems are blamed on the fuel system when in fact the problems could be poorly adjusting valves or ignition problems.
thelogo
post Mar 14 2017, 09:50 PM
Do or dont get me wrong djet is great
If they start makeing all new parts id buy them and go go go
(IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/yellowsleep[1].gif)
With the exception of guys who shouldnt own a screwdriver
Carbs are universally understood by mechanics all across the world and the guys that know djet are either too old or retired to fix/ fiddle with it (IMG:style_emoticons/default/poke.gif)
Im hopeing for a hail mary with this cb performance f.i kit
But if it ends up carbs so be it
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 2nd April 2026 - 08:58 AM
