Clutch Tube Repair, How to do it? |
914 |
Mar 18 2017, 08:20 PM
Senior Member Group: Members Posts: 449 Joined: 26-December 02 Member No.: 19 Region Association: Southern California |
When I depress the clutch I here a clicking in the tunnel..The cable is maxed out with spacer nuts at the transmission end..What is the easiest way to do it as not to cut into the tunnel or weld..Is there a way?
Thanks,914 |
JeffBowlsby |
Mar 19 2017, 09:36 AM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Use the search function on this site...Google may get you there but its easier here.
A broken clutch tube cannot be adjusted around, it needs to be repaired. Attached image(s) |
914 |
Mar 19 2017, 11:08 AM
Jeff,
Can you arrow the spots at the tube is welded to.. I think i see them But your the Expert.. Thanks,914 Use the search function on this site...Google may get you there but its easier here. A broken clutch tube cannot be adjusted around, it needs to be repaired. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:05 PM |
