Clutch Tube Repair, How to do it? |
914 |
Mar 18 2017, 08:20 PM
Senior Member Group: Members Posts: 449 Joined: 26-December 02 Member No.: 19 Region Association: Southern California |
When I depress the clutch I here a clicking in the tunnel..The cable is maxed out with spacer nuts at the transmission end..What is the easiest way to do it as not to cut into the tunnel or weld..Is there a way?
Thanks,914 |
Dave_Darling |
Mar 18 2017, 10:14 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If only the front is loose, you can drill into the side of the tunnel (forward of the shifter) and plug weld the bracket onto the tunnel again. McMark did that to my car.
--DD |
Lo-Fi Version | Time is now: 5th May 2024 - 12:49 PM |
