Clutch Tube Repair, How to do it? |
914 |
Mar 18 2017, 08:20 PM
Senior Member Group: Members Posts: 449 Joined: 26-December 02 Member No.: 19 Region Association: Southern California |
When I depress the clutch I here a clicking in the tunnel..The cable is maxed out with spacer nuts at the transmission end..What is the easiest way to do it as not to cut into the tunnel or weld..Is there a way?
Thanks,914 |
mgphoto |
Mar 19 2017, 08:45 AM
"If there is a mistake it will find me" Group: Members Posts: 1,338 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
This repair can be avoided with the correct adjustment of the cable clevis, pedal stop and often overlooked thoughout bearing lever pivot ball, which needs to be repositioned to keep the mechanism within mechanical limits, when flywheel resurfacing is done.
Mike |
Lo-Fi Version | Time is now: 5th May 2024 - 11:11 AM |
