Clutch Tube Repair, How to do it? |
914 |
Mar 18 2017, 08:20 PM
Senior Member Group: Members Posts: 449 Joined: 26-December 02 Member No.: 19 Region Association: Southern California |
When I depress the clutch I here a clicking in the tunnel..The cable is maxed out with spacer nuts at the transmission end..What is the easiest way to do it as not to cut into the tunnel or weld..Is there a way?
Thanks,914 |
eyesright |
Mar 19 2017, 04:57 PM
Member Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
When I depress the clutch I here a clicking in the tunnel..The cable is maxed out with spacer nuts at the transmission end..What is the easiest way to do it as not to cut into the tunnel or weld..Is there a way? Thanks,914 http://www.914world.com/bbs2/index.php?sho...=298186&hl= Here's my solution. If its what you need, PM me with your address and I'll send you one of my leftover prototypes to start you off. |
Lo-Fi Version | Time is now: 5th May 2024 - 10:32 AM |
