Novice muffler install - advice needed |
pugface |
Mar 19 2017, 04:29 PM
Newbie Group: Members Posts: 15 Joined: 8-January 17 From: Boerne, TX Member No.: 20,735 Region Association: None |
Hi guys
Often time when I am trying to do some work on my car, I find instructions that skip certain things because 'everybody knows' some steps. Unfortunately, I don't know all the little tips and tricks. I just pulled off my exhaust - the car came with a a Bursch glasspack exhaust that makes a terrible sound. My car also came with a bunch of spares, I thought I'd try the stock muffler that came in the pile. Although there were no gaskets when I removed the old muffler, I assume there should be? Also, occaasioanly I see reference to copper nuts, copper paste, anit-seize - are there extra things I should be doing besides just using a new gasket and a bolt from Ace hardware? I would like to be able to get this muffler off in a year or so, so any tips are appreciated! Thanks pf |
Dion |
Mar 19 2017, 05:15 PM
RN Group: Members Posts: 2,764 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
PF you'll need the appropriate gaskets for the type
of heat exchanger you have: 1.7,1.8,2.0? There are no "copper" nuts per se. I think you are referring to the nuts that go on the heat exchanger when mounting to case. They are sometimes copper color. I just used the appropriate nut/bolt on muffler with a little anti-seize. Torque appropriately. |
Lo-Fi Version | Time is now: 6th May 2024 - 10:51 PM |
